Wired Intelligent Edge
last person joined: 2 hours ago
How do we check local files in 6300M?
  • 1.  How do we check local files in 6300M?
    Posted 5 days ago
    Not sure if I should post my question here.
    Just wonder where the output/redirected files go/save to and how do we show local storage of 6300M?
    show running-config | redirect "abc.txt"
    Thanks.
  • 2.  RE: How do we check local files in 6300M?
    Posted 2 days ago
    The following command will show some files on the system, but not all of them:
    switch# diag
    switch# diag storage filesystem all list
    You can use the Linux shell on the switch to list all the files there.
    The output of your command is redirected to a file in the "/tmp" directory. Here an example how to check it via the shell:
    switch#  start-shell
    switch:~$ ls /tmp
    switch:~$ cat /tmp/abc.txt
