how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
  • 1.  how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 23, 2014 11:14 AM
    How do we restrict command authorizations to permit changes gigabitEthernet only while not allowing changes to tenGigabitEthernet
    the idea is to restrict changes to 10gig ports which are usually trunk ports and critical.
    I tried different combinations with different command argument restrictions but not getting through.
  • 2.  RE: how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 23, 2014 11:31 AM
    If you are an Aruba partner, go to https://afp.arubanetworks.com/afp/index.php/ and login with your partner credentials.
    Search for "tacacs command authorization".
  • 3.  RE: how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 23, 2014 04:05 PM
    HI Colin,
    Generic tacacs authorization setup with privilage level 15 access and restricted access with permitting few commands is already set up and it is working correctly. Sorry if i did not convey my question.
    My requirement is very specific allowing changes on a gigethernet ports and not allowing changes on tengigethernet ports for a user.
     I am trying to do this with command arguments , but it either permits both or denys both. i feel it is not processing further once the first command argument matches.
  • 4.  RE: how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 23, 2014 04:19 PM
    wifiabcd,
    What version of ClearPass are you using and What Cisco device?
  • 5.  RE: how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 24, 2014 03:11 AM
    Cisco Version
    Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE2, RELEASE SOFTWARE (fc1)
    Technical Support: http://www.cisco.com/techsupport
    Copyright (c) 1986-2013 by Cisco Systems, Inc.
    Compiled Tue 05-Feb-13 11:53 by prod_rel_team
    ROM: Bootstrap program is C3750E boot loader
    BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
    Clearpass Version
    ClearPass Policy Manager 6.2.5.61640 on CP-VA-5K platform
    Also attaching the tacas enforcemet profile export from my system , and with this i am getting the following result, I am able to do both , but if i `check the ummatched commands to "deny" then both will be denyed.
    ArubaCPP-Test(config)#inter
    ArubaCPP-Test(config)#interface gi
    ArubaCPP-Test(config)#interface gigabitEthernet 1/0/20
    ArubaCPP-Test(config-if)#exit
    ArubaCPP-Test(config)#interface te
    ArubaCPP-Test(config)#interface tenGigabitEthernet 1/0/1
  • 6.  RE: how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 24, 2014 03:15 AM
    Attachment was not possible hence pasting the xml
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
    <TipsHeader exportTime="Mon Mar 24 09:48:10 AST 2014" version="6.2"/>
    <TacacsEnfProfiles>
    <TacacsEnfProfile description="" name="Cisco Restricted" maxPrivLevel="15">
    <ServiceNameList>
    <string>Shell</string>
    </ServiceNameList>
    <ServiceAttrList>
    <RulesCondition valueDispName="15" value="15" oper="EQUALS" name="priv-lvl" type="Shell"/>
    <RulesCondition valueDispName="180" value="180" oper="EQUALS" name="timeout" type="Shell"/>
    </ServiceAttrList>
    <CmdAutzSet permitUnmatchedCmds="false" type="shell">
    <CommandList>
    <Command permitUnmatchedArgs="false" cmd="show">
    <ArgumentList>
    <Argument permit="true" cmdArg="running-config"/>
    </ArgumentList>
    </Command>
    <Command permitUnmatchedArgs="false" cmd="exit">
    <ArgumentList>
    <Argument permit="true" cmdArg="exit"/>
    </ArgumentList>
    </Command>
    <ArgumentList>
    <Argument permit="true" cmdArg="running"/>
    </ArgumentList>
    </Command>
    <ArgumentList>
    <Argument permit="true" cmdArg="interfaces"/>
    </ArgumentList>
    </Command>
    <Command permitUnmatchedArgs="true" cmd="configure"/>
    <Command permitUnmatchedArgs="true" cmd="show"/>
    <Command permitUnmatchedArgs="true" cmd="interface">
    <ArgumentList>
    <Argument permit="false" cmdArg="TenGigabitEthernet"/>
    <Argument permit="true" cmdArg="GigabitEthernet"/>
    </ArgumentList>
    </Command>
    <Command permitUnmatchedArgs="true" cmd="switchport"/>
    <Command permitUnmatchedArgs="true" cmd="write"/>
    <Command permitUnmatchedArgs="true" cmd="interface"/>
    </CommandList>
    </CmdAutzSet>
    </TacacsEnfProfile>
    </TacacsEnfProfiles>
    </TipsContents>
  • 7.  RE: how do we restrict command authorizations to permit changes gigabitEthernet only in CPPM Tacacs
    Posted Mar 24, 2014 05:03 AM
    Do you have this configured on the Cisco side?
    aaa authorization commands 15 default group tacacs+ if-authenticated
    aaa authorization commands 15 defaut group tacacs+ local
    aaa authorization config-commands
