how do you convert ap-103 from a CAP to a RAP
  • 1.  how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 01:25 AM
  • 2.  RE: how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 01:32 AM
    No need to convert. When using a controller, any AP can be deployed as a campus or remote AP.
  • 3.  RE: how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 01:39 AM
    i have a 650 controller but not able to access to web GUI i have 12 AP 93's but not able to use them.  I have also a IAP-103 i ordered a AP-103 and it does not work with the IAP-103 any advice wold be apeciated i am stuck at the moment
  • 4.  RE: how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 01:43 AM
    seem the simple solution would be to order another IAP-103
  • 5.  RE: how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 02:01 AM
    Hmm, that's a wild mix of end-of-sale components.
    You could possibly get them all to work together in a controller based deployment, but that limits you SW choices to AOS 6.4, which is the only one supported by all of these components.
    An AP-103 cannot be converted to IAP-103, so it cannot be used in a controller-less (Instant) network.
  • 6.  RE: how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 02:18 AM
    i only need 4 AP's for this project i had the AP-93's left over from a project that they where not used on so i ordered the 650-us controller but not able to get it to work as well. That would have been my prefered method. instaed i had one IAP-103 I was able to setup and log in via the web GUI. so i have opted to us IAP-103's this is for my home network to connect my shop and my home to a mesh network. shop and home are on the same LAN
  • 7.  RE: how do you convert ap-103 from a CAP to a RAP
    Posted Jan 16, 2020 01:42 PM
    What AOS code version are you running on that 650 controller?
    Did you reset the AP-93 access points to factory defaults?
