How do you delete Mac address from db
  • 1.  How do you delete Mac address from db
    Posted Feb 12, 2013 12:42 PM
    We have a laptop that was on our main ssid for valid users and known machines. I want now to remove its Mac address from the internal db so it will be able to connect to our guest network.
    once a machine authenticates to our main ssid it then cannot connect to our guest network
  • 2.  RE: How do you delete Mac address from db
    Posted Feb 12, 2013 01:14 PM
    Good evening,   :smileytongue:
    Here u go:
    Via cli:
    (3600) #aaa user delete ?
    A.B.C.D                 Match IP address
    all                     Delete all users
    ap-ip-addr              Match AP IP address
    ap-name                 Match AP name
    mac                     Match MAC address
    name                    Match user name
    role                    Match role name
    Via gui:
    u can blacklist and then unblacklist the user...it will do the same :)
    If this post helped u please K+ (The star + button ) me and mark as solved!    :smileyhappy:
  • 3.  RE: How do you delete Mac address from db
    Posted Feb 12, 2013 01:27 PM
    we have 6000's controlers
    and in gui we have o blacklisted clients and have no option to add any
    in cli aaa user delete mac address is not getting me there either
    any other thoughts? :smileyhappy:
  • 4.  RE: How do you delete Mac address from db
    Posted Feb 12, 2013 01:30 PM
    in gui
    u need to go to clinet list (under monitoring) and than mark/choose the client u want and press on the button "blacklist" in the bottom!
    in the cli - did u enabled first? by enter into enable mode?
    BTW:
    in all the aruba controller all the gui/cli commands are the same (it's depands on the AOS)
  • 5.  RE: How do you delete Mac address from db
    Posted Feb 12, 2013 01:32 PM
    If you want to delete someone form the internal database go to
    security
    authentication
    server
    Internal server and you can delete fromt here... here is a screenshot.. deletedb.PNG
  • 6.  RE: How do you delete Mac address from db
    Posted Feb 12, 2013 01:29 PM
    You can do it from the WebUI or CLI.    This would be done on the master controller (unless each local controller is using its own internal DB).
    WebUI:
    Configuration --> Authentication --> Servers --> Internal DB
    Find the MAC and delete it
    CLI:
    local-userdb del username <mac of device>
  • 7.  RE: How do you delete Mac address from db
    Yep clembo
    ightshdae are right...i didn't understood your question up to the end :)
  • 8.  RE: How do you delete Mac address from db
    Posted Feb 12, 2013 02:07 PM
    thanks clembo, just seems like there should be more clients in db 204 and actually cannot find suspect one. Hmm cannot connect laptop to any Aruba ssid's but can to public one. May be another issue here
