How do you disable NTP monlist command on AMP servers
  • 1.  How do you disable NTP monlist command on AMP servers
    Posted Jan 27, 2014 05:13 PM
    Trying to find out how to disable the ntpd monlist command, or how to upgrade ntp to 4.2.7.
  • 2.  RE: How do you disable NTP monlist command on AMP servers
    Posted Jan 27, 2014 09:41 PM
    You can add the following to the /etc/ntp.conf (although I would work with TAC before you change that)
    restrict default kod nomodify notrap nopeer noquery
  • 3.  RE: How do you disable NTP monlist command on AMP servers
    Posted Jan 28, 2014 09:23 AM
    Thanks, I found that as well.  It looks like you can also disable for IPV6 with "restrict -6 default kod nomodify notrap nopeer noquery".  I'll follow up and let you know how it works out.
  • 4.  RE: How do you disable NTP monlist command on AMP servers
    Posted Jan 28, 2014 12:01 PM
    To update, you can do:
    # yum update ntp
  • 5.  RE: How do you disable NTP monlist command on AMP servers
    Posted Jan 30, 2014 09:31 AM
    Looks like it worked.  Thanks!
