Thanks, what power levels do you actually use? I have two different RF Management > 2.4 GHz Radio Profiles:
- a "low power" one for dense areas, with min/max EIRP limits of 3 and 9;
- a "med power" with min/max of 6 and 12.
(I'd read once not to set more than a 6 dBm range, but not sure if that still holds.)
We set the low power profile in dense areas, and the medium profile in less-dense areas.
With those settings, the lowest 2.4 EIRP shown in our "Radios" table is 4dBm, and only a few APs have that setting. Many are at 9dBm, which I take it as meaning the system might turn them up higher if it could, but they are at the limit.
Also, a ton of our 2.4 radios show more than 50% Rx channel busy
Steve Bohrer
IT Infrastructure, Emerson College
Original Message:
Sent: Jul 15, 2024 07:50 AM
Subject: How do you disable selected 2.4GHz radios?
Further turning down your 2.4GHz power levels may work as well.
I would go for the ap-group approach, because as you mention per-ap exceptions are hard to handle and error-prone.
Original Message:
Sent: Jul 14, 2024 05:04 PM
Our network is a mix of AP-215, AP-315, AP-335, AP-515, and AP-635; we are in the process of upgrading the older 2XX deployments to AP-635.
2.4 overlap has been an issue for a long time, as adequate 5GHz density (and now 6GHz density) puts too many 2.4GHz radios to avoid multiple APs in each of the three channels in each area.
Aruba 6 had an automatic solution that turned off some 2.4 radios, but it was dropped from Aruba 8, presumably because it didn't actually work very well.
Ekahau and other design tools suggest which 2.4 radios to disable, but I am not sure the easiest or best way to do it:
One solution is to split each existing AP group in to two, one of which has 2.4 disabled, and then assign all the APs to one of the groups.
Alternatively, it could be applied on an a per AP basis, using the "Per AP Override"
Both options seem annoying to manage: either I have twice as many groups, or, I have a bunch of obscure and hard to maintain individual config. How do you handle this?
(Obviously, the third option is just to leave all the 2.4 radios on, and have lots of CCI in 2.4. This is actually what I have been doing, but it doesn't seem ideal)
Steve Bohrer
