How does Clearpass check which device is which?
  • 1.  How does Clearpass check which device is which?
    Posted Nov 19, 2014 03:33 PM
    Hello guys and girls,
    I was trying to figure out how to check in clearpass how it know it's for example a mobile, or a laptop.
    This is because I thought I read somewhere (can't remember where), that I needed to configure on remote switches where AP's are connected to, a ip helper address to point to the clearpass.
    Otherwise it would not know if it's a laptop or mobile.
    Could someone help me please?
    Thanks in advance for your help!
  • 2.  RE: How does Clearpass check which device is which?
  • 3.  RE: How does Clearpass check which device is which?
    Posted Nov 21, 2014 02:56 AM
    Please look at a newer TechNote I published on this subject.
    ClearPass Profiling TechNote V1.1.pdf
  • 4.  RE: How does Clearpass check which device is which?
    Posted Nov 19, 2014 03:42 PM
    Please go to
     https://<ip address of clearpass server>/tipshelp/html/en/index.htm#CPPM_UserGuide/Profiling.htm
    and
    https://<ip address of clearpass server>/tipshelp/html/en/index.htm#CPPM_UserGuide/EndpointProfiles.html
    Also, search for profiler in the online help for a full explanation.
  • 5.  RE: How does Clearpass check which device is which?
    Posted Nov 21, 2014 09:55 AM
    You can also go to the following in Clearpass:
    Configuration > Identity > Endpoints
    to see how those devices are currently being classified within the system.
    -Mike
