How enable WIP?
  • 1.  How enable WIP?
    Posted May 19, 2024 08:37 AM
    Hi
    I have Aruba 9004 with 8.11, running in standalone mode and add lic-ap, lic-pef, lic-rfp. Can it enable WIP without Mobility  Conductor?
  • 2.  RE: How enable WIP?
    Posted May 19, 2024 10:53 PM
    yes you should be able to do that without a need for Mobility conductor.
    from memory using the WebUI, under configuration->tasks there should be a wizard for intrusion detection/protection
  • 3.  RE: How enable WIP?
    Posted May 20, 2024 03:34 AM
    Great! Thank you, ariyap!
