Network Management
How I can add active directory in Airwave
  • 1.  How I can add active directory in Airwave
    Posted Jan 17, 2013 10:44 PM
  • 2.  RE: How I can add active directory in Airwave
    Posted Jan 18, 2013 12:29 AM
    If you mean for manage the Airwaves with Active directory accounts here is how
  • 3.  RE: How I can add active directory in Airwave
    Posted Jan 18, 2013 01:05 AM
  • 4.  RE: How I can add active directory in Airwave
    Posted Jan 18, 2013 10:09 AM
    client don't want use Radius so how i can setup Active Directory with LDAP ?
  • 5.  RE: How I can add active directory in Airwave
    Posted Jan 18, 2013 02:54 PM
    In 7.6.1, I see that there is an option to use LDAP.
    The user guide has a sectio on configuring it on page 41: http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=9101
  • 6.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 02:50 PM
    Hi there
    I'm trying to use my windows domain account to log onto airwave without using the local admin account.
    How can I do that?
  • 7.  RE: How I can add active directory in Airwave
  • 8.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 06:04 PM
    Hey there
    I tried tacas and radius but neither work. I dont see any authentication to my ACS.
    Could it be denied on the airwave itself?
  • 9.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 07:14 PM
    Did you set it up like the article says?
    You should configure Airwave in one browser and use a different browser to try to authenticate so that you don't get locked out.
  • 10.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 07:55 PM
    Yes I did. I dont think its making it past the airwave device.
  • 11.  RE: How I can add active directory in Airwave
  • 12.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 08:14 PM
    None of those options are in ACS 5.5 for radius. I'm using AirWave Management Platform 8.2.0.
  • 13.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 08:38 PM
    Only the Airwave instructions.  Not the TACACS ones.
    We only want you configure Airwave so that you at least see the authentications coming in at the TACACS server...
  • 14.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 08:48 PM
    I did set it up.
  • 15.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 09:06 PM
    Please open a TAC case.  It is hard to know what is wrong from the limited information here.
  • 16.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 09:16 PM
    I'm using Radius.
  • 17.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 09:28 PM
    Radius uses either port 1645 or 1812 for authentication, not 1700.  I would change the port in Airwave to either 1645 or 1812, instead of 1700.
    The port 1700 in the TACACS server is for COA, which is different from authentication.
    That would explain why you are not seeing anything.
  • 18.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 09:51 PM
    On the ACS Server it only has the COA port which is 1700. I changed it to 1812. still cant log in.
  • 19.  RE: How I can add active directory in Airwave
    Posted Apr 07, 2016 10:43 PM
    Again, the COA port should not be changed, because it has nothing to do with authentication.  The Radius Server automatically answers on 1645 or 1812 for authentication.
    What do you use the ACS server for right now?
  • 20.  RE: How I can add active directory in Airwave
    Posted Apr 08, 2016 10:14 AM
    I use it for wireless authentication, device management of aruba controllers and cisco switches. I dont get it. Its not evening getting past the Airwave device.
