How I can configure one rule for destination Nat in IAP?
  • 1.  How I can configure one rule for destination Nat in IAP?
    Posted Feb 22, 2013 04:01 AM
    I need to send to external proxy all http traffic. In ARUBAOS for controller is simple, but not how the IAPs. Thanks
  • 2.  RE: How I can configure one rule for destination Nat in IAP?
    Posted Feb 22, 2013 04:14 AM
    hi.
    as far as i aware its not supported using InstantAP.
    This is not possible on Aruba Instant and would probably have to be done on the upstream router (branch most likely).
  • 3.  RE: How I can configure one rule for destination Nat in IAP?
  • 4.  RE: How I can configure one rule for destination Nat in IAP?
    Posted Feb 22, 2013 07:49 AM
    Have you tried using the Destination-NAT action within the policy rules?  Is this what you are trying to do?
  • 5.  RE: How I can configure one rule for destination Nat in IAP?
    Posted Mar 08, 2013 04:46 PM
    I don't see destination NAT in the action tab, what software/license level are you on?
  • 6.  RE: How I can configure one rule for destination Nat in IAP?
    MVP EXPERT
    Posted Mar 14, 2013 05:38 PM
    It is present in the latest release :)
  • 7.  RE: How I can configure one rule for destination Nat in IAP?
    Posted Oct 16, 2014 03:37 AM
    Hi All,
    Did this ever get resolved. I have a cusotmer trying to do the same thing; redirect HTTP traffic on an SSID to a proxy server on port 9090. We tried the config above but it does not work.
