How I can connect 2 AP-105 without Controller
  • 1.  How I can connect 2 AP-105 without Controller
    Posted Nov 08, 2018 02:36 PM
    I have 2 AP-105 and I want to connect one of them to the router to have internet and the other one I want to put it on other office just closed to have internet coming from the first one.
    Without using the controller because I dont have it.
    How I can do that please?
    Thank you !
  • 2.  RE: How I can connect 2 AP-105 without Controller
    Posted Nov 08, 2018 02:50 PM
    You can only do that with an IAP-105.  AP-105s require a controller.  The sticker on the back of the AP should tell you what model you have.
  • 3.  RE: How I can connect 2 AP-105 without Controller
    Posted Nov 08, 2018 03:00 PM
    Thank you so much for your reply but I have AP-105.
    I can use Mesh for that? without controller?
  • 4.  RE: How I can connect 2 AP-105 without Controller
    Posted Nov 08, 2018 06:13 PM
    You cannot configure AP-105s without a controller at all.  They depend on a controller to work.
  • 5.  RE: How I can connect 2 AP-105 without Controller
    Posted Dec 14, 2018 08:22 PM
    Regarding the AP-105's, would they work with the Aruba 200 Controller or the ARUBA 800 LAN Mobility Controller? Is any additional licensing required to run a basic wireless network. Thanks in advanced.
  • 6.  RE: How I can connect 2 AP-105 without Controller
    Posted Dec 15, 2018 08:10 AM
    They can work with an AP 200 or an 800 controller.  The 200 and the 800 would require licenses for the access points to connect.  If you obtain the 200 or 800 controllers, you need to find out from the seller if there are any licenses, first...
