How I can console to AP 315
This thread has been viewed 122 times
  • 1.  How I can console to AP 315
    Posted Nov 12, 2017 04:26 AM
      I just noticed that Aruba 315 doesn't have a console port. Any idea how to console to this AP?
  • 2.  RE: How I can console to AP 315
    Posted Nov 12, 2017 05:58 AM
    it does have, it's under the rubber rectangle in the top left, see attached image.
    You need a suitable serial cable for it - e.g. an Aruba ap-cbl-ser (but a bit pricey) or buy a ttl-to-rs232 converter or ttl-to-usb adaptor online from ebay/taobao/amazon, they are popular for rasberry pi etc., see the post by Tamaz here
    http://community.arubanetworks.com/t5/Wireless-Access/AP-CBL-SER-Cable-Diagram/m-p/193193#M38727
  • 3.  RE: How I can console to AP 315
    Posted Nov 13, 2017 01:36 AM
    Thanks, that was helpful.
  • 4.  RE: How I can console to AP 315
    Posted Nov 05, 2018 11:18 PM
    I used a Raspberry PI 3 directly connected to the Aruba AP-315 and was successful at getting into the console.
    1.  sudo raspi-config -> Interface Options -> Serial -> Would you like a login shell? (NO) -> Would you like serial port hardware? (YES) -> Finish -> reboot
    2.  sudo apt install minicom
    3.  Connect  the following
         Aruba pwr  -> GPIO1 (3.3V)
         Aruba grnd -> GPIO6 (GND)
         Aruba TX   -> GPIO10 (RXD0)
         Aruba  RX -> GPIO08 (TXD0)
    4.  minicom -b 9600 -o -D /dev/ttyS0
    You should be in!
  • 5.  RE: How I can console to AP 315
    Posted Jul 13, 2020 02:21 AM
  • 6.  RE: How I can console to AP 315
    Posted Feb 24, 2019 11:11 PM
    Just in case anyone needs the exact pinout. Working 100% with my little USB2TTL.
  • 7.  RE: How I can console to AP 315
    Posted Jan 30, 2022 01:38 PM
    I confirmed this pinout works perfectly on the IAP-315! I used a HiLegato FT232RL, so the only difference was making sure the jumper on the board was set to 3.3v.
    Rich West
