Location Services
  • 1.  How I can create a HeatMap using Meridian SDK
    Posted Jul 24, 2019 08:47 AM
    I'm using meridian SDK on iOS for an internal application, I need to generate a HeatMap specific for each mobile device ( one device per user). I have an Acces Point as a Location beacon on each room.
    For example :
    Inside the office I will start my day: I click on a button in myApp using Meridian SDK, this button also start monitoring for campaigns
    (i will also use proximity beacons) .
    A few hours later, I click on the stop button in myApp and a heatmap of all my movements will be generated!
    I see this article but I don't know if it's working for my need :
    https://docs.meridianapps.com/article/529-the-heatmap-report
    Thanks in advance
    #LocationServices
    #ALE
    #Meridian
  • 2.  RE: How I can create a HeatMap using Meridian SDK
    Posted Jul 24, 2019 01:02 PM
    Are you not able to generate report in https://edit.meridianapps.com , once you login go to location and in right side we have list of options, click on  Reports tab and choose available options to generate reports
    heatmaps/devices/campagins/location sharing/General
  • 3.  RE: How I can create a HeatMap using Meridian SDK
    Posted Jul 24, 2019 04:42 PM
    Hi Pavan,
    Thank for your response currently, the reports tab don't work correctly
    But is not exactly what I want, I would like to generate a heatmap directly with my mobile application using the meridian SDK for iOS and on the generated heatmap I would like only records movement of the current user.
    How I can use the meridian SDK to do this? If it is not possible directly what are alternatives?
    Thanks in advance
  • 4.  RE: How I can create a HeatMap using Meridian SDK
    Posted Jul 25, 2019 09:27 AM
    I believe it is not possible now, you can drop email to meridian support for more details
    hpe-aruba-meridian@hpe.com
