How i can see the AP Signal Strength in dbm when ARM is running
  • 1.  How i can see the AP Signal Strength in dbm when ARM is running
    Posted Oct 28, 2013 10:09 AM
    can anybody help me  to find the signal strength in dbm for an running Accesspoint 105 with ARM enabled.
    I have used the folloowing cli command -- #show ap arm history ap-name xxxx-ap1
    Output:
    Interface :wifi0
    ARM History
    Time of Change       Old Channel  New Channel  Old Power  New Power  Reason
    2013-10-25 16:04:54  132+         36+          24         24         I
    2013-10-21 13:11:40  132+         132+         21         24         P+
    2013-10-21 13:07:12  132+         132+         18         21         P+
    I: Interference, R: Radar detection, N: Noise exceeded, E: Error threshold exceeded, INV: Invalid Channel, G: Rogue AP Containment, M: Empty Channel, P+: Increase Power, P-: Decrease Power, OFF: Turn off Radio,
    What is the value from Old/New Power for a definition -- is that DB, DBM, mWatt ............
    Many thanks for your help.
    Cheers Roland
  • 2.  RE: How i can see the AP Signal Strength in dbm when ARM is running
    Posted Oct 28, 2013 10:18 AM
    "show ap arm rf-summary ap-name <your ap name>" will show you the current arm assignment which will include the channel and power in dbm.
  • 3.  RE: How i can see the AP Signal Strength in dbm when ARM is running
    Posted Oct 28, 2013 10:23 AM
    If you run the following command you could see it :
    The EIRP is in dB
    show ap active
    Active AP Table
    Name                     Group         IP Address   11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime           Outer IP
    test-225-3               Feldberg-106  10.66.8.153  1            AP:HT:1/9/21         1            AP:HT:36+/15/21      225      Ada    18d:13h:19m:22s
    (controller) #show  ap  arm rf-summary ap-name test-225-3
    HT Channel Summary
    channel_pair  Pairwise_intf_index
    149-153       53
    36-40         31
    157-161       57
    44-48         48
    Interface Name           :wifi0
    Current ARM Assignment   :36+/15
    Covered channels a/g     :3/0
    Free channels a/g        :5/0
    ARM Edge State           :enable
    Last check channel/pwr   :5m:47s/3m:1s
    Last change channel/pwr  :2h:11m:22s/1h:17m:36s
    Next Check channel/pwr   :48s/3m:1s
    Assignment Mode          :Single Band
    Interface Name           :wifi1
    Current ARM Assignment   :1/9
    Covered channels a/g     :0/2
    Free channels a/g        :0/1
    Last check channel/pwr   :1m:17s/1m:17s
    Last change channel/pwr  :1m:17s/1m:17s
    Next Check channel/pwr   :4m:55s/6m:7s
  • 4.  RE: How i can see the AP Signal Strength in dbm when ARM is running
    Posted Oct 28, 2013 10:27 AM
    Hi
    tbeachwcu, victorfabian
    Thats the solutions - Many thanks for your help
    Greetings Roland
