last person joined: 7 hours ago
How i design ClearPass solution with onboard
  • 1.  How i design ClearPass solution with onboard
    Posted Jan 26, 2016 10:19 PM
    If number of authenticated device is more 25,000 devices in HQ. Within HQ is separated 3 buildings. How i desire number of Cleapass hardware ?
    User behaviour,  they must move between each building but I concerd about BYOD (onboard) solution
    If i place clearpass on each building. User A registered own device on ClearPass at building1 and User A walk to building2. Must User A register own device again ? because I think ClearPass database is seperated.
    How I design and solve this problem
  • 2.  RE: How i design ClearPass solution with onboard
    Posted Jan 26, 2016 10:23 PM
    ClearPass is clustered. The same data will exist on all 3 boxes and users will be able to authenticate without issue.
    You should work with your ClearPass partner on a design.
    Sent from Nine
  • 3.  RE: How i design ClearPass solution with onboard
    Posted Jan 26, 2016 10:28 PM
    And when I want to manage Clearpass, I must access clearpass each box or I can manage all clearpass via 1 ip address
  • 4.  RE: How i design ClearPass solution with onboard
    Posted Jan 26, 2016 10:30 PM
    It would be managed through the publisher, yes.
    Sent from Nine
