How is "PL" calculated in "show ap arm neighbors" output?
  • 1.  How is "PL" calculated in "show ap arm neighbors" output?
    Posted Aug 05, 2014 10:36 PM
    The manual on this CLI comand seems to be outdated.  "show ap arm neighbors" gives the following fields:
    bssid essid channel rssi tx-power PL (dB) AP Flags Last Update (Total updates)
    I'm guessing "PL" might stand for "Path Loss"?  How is it calculated?
    Also I think it's safe to assume that the "tx-power" is that of the neighbor, taken either OTA in an IE or taken from the controller radio db, and that RSSI is the local RSSI and not from a remote-side value from an OTA IE, correct?
