How LAG works with AP-225
  • 1.  How LAG works with AP-225
    Posted Jul 26, 2013 09:24 AM
    I been looking for a document that explains the logic of how LAG will work for the AP225/224 and how it will accomplish the 1.3 Gbps speeds
    How is it going to build the GRE tunnels ? and how can you configure the switch ( just a normal port-channel config) ?
  • 2.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 09:50 AM
    NOTE - this is for a centralized controller based deployment.
    Basically, the gist is that each radio (2.4 and 5) on the AP will correspond to either port 1 or port 2 in the LAG.
    The switch must be configured to support a LAG based on Source IP address (from the controller).  There will be two GRE tunnels built and based on the previous statement, traffic will always enter the appropriate port to the AP.  The issue isn't the upstream traffic...it's the downstream.
    If you consider the following statements:
    1. Most Ethernet switches support Etherchannel load-balancing based on some combinations of the 5-tuple <src mac, dest mac, src IP, dest IP, protocol>
    2. In a centralized WLAN architecture, all traffic tunneled between the AP and the control have the same outer IP header and 5-tuple
    So, from a LAG perspective...all traffic looks the same and is therefore hashed out in the same manner.
    Aruba intends to initally solve this by configuring two consecutive IP addresses to the controller so that alternate IP addresses can be used for different GRE tunnels between the AP and the controller.  This ensures traffic from the controller to the AP will have different source IP addresses in the outer IP header based on the destination radio interface.
    At the end of the day, the AP aggregate throughput is < 1Gbps.
  • 3.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 10:02 AM
    Very interesting .
    Thanks for the explanation
    Seth where can I find this information ?
  • 4.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 10:03 AM
    When we release support for the LAG on the AP225 then it should be included in the release notes.
  • 5.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 10:04 AM
    Do you know in what version AOS this will be supported ?
  • 6.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 10:05 AM
    6.3.1.0
  • 7.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 10:07 AM
    It would be nice if there was a technote about this setup.
  • 8.  RE: How LAG works with AP-225
    Posted Jul 26, 2013 10:08 AM
    I will make a note of it and encourage the same
  • 9.  RE: How LAG works with AP-225
    Thanks Seth
