Yes ,it connect to the nework .Only set the ip address .Vlan 1 .very simple configuration .
Original Message:
Sent: Mar 13, 2023 07:54 AM
Subject: How long does your Aruba 7010 take to reload ? Mine will take more than 1 hour
Hi, is the controller connected to the network? can you share the vlan of the controller IP and the ports configuration?
Original Message:
Sent: Mar 12, 2023 08:51 PM
Yes ,error message resloved by secondly upgrade . Now the issue is still take 1 hour to boot while I use AOS 8.3 or 8.6 . 6.5 only take 10 minutes.
Original Message:
Sent: Mar 12, 2023 07:45 PM
Hi, when you get that error just load/upgrade the OS again. Use the cli to do it if you can't open the GUI.
I hope this helps.
Original Message:
Sent: Mar 12, 2023 07:37 AM
I downgrade to 6.5.3 ,it only take 3 minutes to reboot .There is an error See below image.
Original Message:
Sent: Mar 12, 2023 07:13 AM
I remember one of my customers have 2x7005 controllers and the boot-time is normal 5-10minutes. FPAPP is responsible for the L2/L3 switching part of the controller. Maybe you can dig into the "show inventory" and find some issue there?
Maybe this topic helps you: https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=22137
Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
Original Message:
Sent: Mar 11, 2023 06:09 PM
I work mostly with minimum 7030 or 72xx controllers so it can be depends on the model but 10 minutes is normal. One hour sound really long and also sugest to open a TAC case.
Original Message:
Sent: Mar 11, 2023 06:43 AM
How long does your Aruba 7010 take to reload ? Mine will take more than 1 hour .Is it normal ?
I tried 8.3 and 8.6 ,all the same result . Most of the time was spend on initializing fpapps ,about one hour. But when it start ,everything is ok .
