how many access point can IAP205H managed?
  • 1.  how many access point can IAP205H managed?
    Posted Jun 11, 2015 11:07 AM
    May I know how many access points that an IAP205H virtual controller can managed?
  • 2.  RE: how many access point can IAP205H managed?
    Posted Jun 11, 2015 11:08 AM
    The recommendation is 128.
  • 3.  RE: how many access point can IAP205H managed?
    Posted Jun 12, 2015 12:10 AM
    What if i have 185 units of AP? What is the suggestion?
    Sent from my Huawei Mobile
  • 4.  RE: how many access point can IAP205H managed?
    Posted Jun 12, 2015 12:16 AM
    Technically it will work, but you should consider splitting into two clusters if possible.
    Tim
  • 5.  RE: how many access point can IAP205H managed?
    Posted Jun 12, 2015 12:27 AM
    How should I go about it? is there any guide to deploy this?
  • 6.  RE: how many access point can IAP205H managed?
    Posted Jun 12, 2015 12:35 AM
    To create to clusters, you would need to have two management subnets. Each subnet would be for a cluster.
    You can set up roaming between the clusters as well. All instructions can be found in the Instant user guide.
    Tim
