How many APs the AP103 can control using the virtual controller??
  • 1.  How many APs the AP103 can control using the virtual controller??
    Posted Apr 08, 2014 04:20 AM
    How many APs the IAP103 can control using the virtual controller??
  • 2.  RE: How many APs the AP103 can control using the virtual controller??
    Posted Apr 08, 2014 04:47 AM
    From what I know there isn't limits on number of IAP103 in a cluster, like IAP105 and other IAPs. You can deploy how many IAP103 you want in your cluster.
    The only thing is taht you must not have IAP93 in your cluster, otherwise you are limit to 16 IAP for cluster.
    [If you found my post helpful, please give kudos]
  • 3.  RE: How many APs the AP103 can control using the virtual controller??
    Posted Apr 11, 2014 10:56 AM
    This is true...there are no limits on the AP103.
