How many Attenuation(dB) on option cables
  • 1.  How many Attenuation(dB) on option cables
    Posted Jun 24, 2013 01:21 AM
    Hi, does anyone knows how many Attenuation(dB) by follows option cables on Frequency 2.4G and 5G ?
    AFC7DL01-00 7D antenna cable with 2 N type Male connectors, 1 meter
    AFC7DL02-00 7D antenna cable with 2 N type Male connectors, 2 meters
    AFC7DL03-00 7D antenna cable with 2 N type Male connectors, 3 meters
    AFC7DL04-00 7D antenna cable with 2 N type Male connectors, 4 meters
    I would like to know reliable level for configure MSR2K.
  • 2.  RE: How many Attenuation(dB) on option cables
    Posted Jun 24, 2013 01:51 AM
    LMR-400 cable has extremely low loss. For the short lengths of these cables, the total loss is dominated by the connector loss, and can be approximated as 0.5dB for all 4 variants.
    /Onno
  • 3.  RE: How many Attenuation(dB) on option cables
    Posted Jun 24, 2013 08:50 PM
    You can find charts online for LMR400 loss by googling "LMR400 loss chart".
    There are also loss calculators online, here is on by Times Microwave which is a major supplier of such cables.  http://www.timesmicrowave.com/cgi-bin/calculate.pl
  • 4.  RE: How many Attenuation(dB) on option cables
    Posted Jun 24, 2013 10:01 PM
    Hi , oharms and clukas.
    Thank you reply.
    yha !! The URL link helps me well.
    I can calculat cable loss by it . Regarding toal loss, I shuld add connector loss whitch might be 0.3dB.
    Am I right ?
    /NKGW
  • 5.  RE: How many Attenuation(dB) on option cables
    Posted Jun 24, 2013 11:00 PM
    Usually 0.25dB is OK for connectors from reputable sources.
  • 6.  RE: How many Attenuation(dB) on option cables
    Posted Jun 24, 2013 11:44 PM
    Okay,
    Thank you for your help !!
