What do you mean by maps?
In RF plan tool there are campuses, buildings, and floors
There is no limit to the number of networks or buildings you can have in visual RF plan, but after a while it becomes difficult to see what's what. As far as floors, I'm not sure if there is a limit, but I would image it would be relavitely high if it's present.
Hope that helps.
