My real problem is like -
i have 5 Aruba 105 IAP working in office.
My users are corporate users and guest user.
My one and only compliance is that dont give access on mobile either guest or corporate user.
Earlier i was doing Manual blacklisting of mac-address of all office mobile user and guest in case they come.
Right now it is showing limited as after 128, user cannot be blacklisted.
So for alternate solution-
IF i do AD integration for local user for AD authentication. ( so only lapotp that are in domain will connect, not mobile)
and for guest user i will use internal server authentication and create users internally as per request .
BUT the loop in this is if internal user share his password to another user so number of user can connect by using same credential.
Please suggest if i can do anything for this....?
