How many devices can be connected to a single Access point?
  • 1.  How many devices can be connected to a single Access point?
    Posted Oct 07, 2019 08:04 AM
    Hello, recently I moved from DAS planing (indoor cellular) to wifi planning and I have a question for Access point user capacity, you see the datasheet says it can handle 250 devices however I talked to many designers and they said most AP can handle between 30-50 devices, now I need to know how many devices I can connect to achieve a target of 8Mbps / device (I need a solid formula to convince my customer) , can you help me?
  • 2.  RE: How many devices can be connected to a single Access point?
    Posted Oct 07, 2019 08:45 AM
    Are you looking for a specific model of AP or just a generic explanation?
  • 3.  RE: How many devices can be connected to a single Access point?
    Posted Oct 14, 2019 03:14 PM
    It all depends on the AP model. We try to limit ours to 60 devices per radio.
  • 4.  RE: How many devices can be connected to a single Access point?
    Posted Oct 15, 2019 02:37 AM
    There is a lot of usefull information in the Aruba High Density VRD
    See this section about: Estimating System Throughput
