That should be possible, there is a guidance (not hard limit) to not exceed 128 APs or 2000 clients. Check the Aruba Instant VRD for further guidance as with larger Instant Clusters the configuration of your wired network becomes more and more relevant for the overall performance. Your Aruba partner or an Aruba certified engineer may be useful to get your deployment operational.
Original Message:
Sent: Mar 16, 2023 04:54 AM
Subject: How many IAPs can I build with AP-303 ?
Hello.
I have a question to ask you.
Use AP-303
I want to build a wireless network.
The question is whether IAP configuration is possible with AP-303 71 units.
Thank you.
