How many IAPs in the same cluster%3F
  • 1.  How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:18 PM
    Is there a recomendation for the number of IAPs in the same cluster?
    Is there a number of SSIDs or segmentariton issue that can influence in the performance?
    I will use 50 IAPs 115 in the same cluster and I need to give some advice.
    Tahnk you.
  • 2.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:20 PM
    You can technically support an unlimited number of Instant APs in a cluster, but the recommendation is 128.
    In general (RF best practice, controller and controller-less), for best performance, you should not exceed 4 SSIDs.
  • 3.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:24 PM
    l
    If I need more than 10 SSIDs, can I segment in more than one cluster to
    Tks, mitigate the performance problem?
  • 4.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:26 PM
    You can do 10, it's just not best practice in regards to air time.
    The best practice means in a single area, so you can different SSIDs on different APs in the same cluster.
  • 5.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:29 PM
    Would you need all 10 SSIDs advertised across all IAPs or would you need a few SSIDs on one IAP and a few on another?  If you want different SSIDs on different APs you can use the AP-Zone feature that just came out with v.4.1.
  • 6.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:36 PM
    Actually, I need to propagate 10 SSIDs in the entire cluster or in each cluster.
  • 7.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 04:49 PM
    You can do that.  IAP supports up to 16 SSIDs with the "Extended SSID" feature enabled.  However, as cappalli mentioned that many SSIDs may hinder performance.
    Take a look at the attached doc.   It is a bit dated, however, the concepts are still current.
    Attachment(s)
    pdf
    AppNote.MultipleBSSIDs.pdf   233 KB 1 version
  • 8.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 05:44 PM
    Here is another interesting article about SSID overhead
    You will find out a ssid overhead calculator as well
    http://www.revolutionwifi.net/p/ssid-overhead-calculator.html
    You should have recommended just 2 SSID and MAX 3 SSID
    Why do you need 10 SSIDs???
    Cheers
    Carlos
  • 9.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 05:50 PM
    In this case the customer will sell the resources using the each SSID to 3 party providers, like an Airport.
    I think that it is possible to solve this problem using Clearpass.
  • 10.  RE: How many IAPs in the same cluster%3F
    Posted Jul 18, 2014 05:55 PM
    You guys have to find a way to not propagate 10 SSIDs... This will make the wifi really slow, and the custumers might start complaining about the wifi service.   And the one that bough it then  will think Dell rebranded wifi is really bad, when its not.
    I know its confidential but we would need to understand how does this work so we can find a way to reduce those 10 SSIDS to 3 at least.
    Cheers
    Carlos
