How many Public CA Certificate on External Captive Portal
  • 1.  How many Public CA Certificate on External Captive Portal
    Posted Jul 20, 2020 04:00 AM
    Hi
    I need to know flow about External Captiveportal from Controller. I don't sure how many Public certificate (CA) for guest.
    I thinks a flow of certification is
    1. Guest Connect to SSID-guest
    2. Redirect to External-Captive Portal
    3. User have receive Login Page and give a HTTPS Server Certificate on Clearpass
    4. User sign-in with username and password then click Login
    5. After Click Login User will redirect back to controller and Give a Server  Certificate on Controller (On controller We not have a public Cert.We have Internal Certificate from AD)
    RedirectBackRedirectBack
    I don't sure it's correct flow?
    We have issue After step 5. We have receive Error page on Browsers.
    I think because my Certificate is not signed from CA.
    How can i use a Public Cert on Clearpass only?  or We must use a two Public Certificate on both.
  • 2.  RE: How many Public CA Certificate on External Captive Portal
    MVP EXPERT
    Posted Jul 20, 2020 04:04 AM
    You will need a certificate installed on CPPM and a certificate installed on the Controller. If this is for Guest user (i.e you have no control of the clients Trust Store or PKI) then it is recommended to also use a public certificate on the Controller as well. As you've highlighted below, you would configure the Web Server Profile to use the Public Cert for Captive Portal use.
  • 3.  RE: How many Public CA Certificate on External Captive Portal
    Posted Jul 20, 2020 06:03 AM
    Thanks.
    I need to know a reason of Public Certificate must using on Controller?
  • 4.  RE: How many Public CA Certificate on External Captive Portal
    MVP EXPERT
    Posted Jul 20, 2020 06:08 AM
    The client will need to Trust the CA of the Captive Portal certificate on the controller so hence the need for a Public cert. The Guest browser will post to CPPM via HTTPS.
