We are expanding office in one of our location and the user count might get close to 90. I would like to know, how much users can connect to a single IAP 135.
Thank you.
Jay :)
AP 135 should handle it
The thing is that it depends.
The quantity of the devices can vary depending in the minimum BW needded per device.
Cheers
Carlos
by default the max users is set to 64, but you can make that higher.
Really though, if you are expecting 90 users, you should have at least another 1 AP.
Max client threshold of 64. allows 64 users on that SSID on 5Ghz, and 64 users on 2.4Ghz correct?
