How many VRRP Instances Needed
  • 1.  How many VRRP Instances Needed
    Posted Jul 25, 2017 09:10 PM
    I have a pair of 7210's in a master/standby setup. I currently have 3 VRRP instances in place.
    VRRP Instance 48 - Serves as LMS for AP's
    VRRP Instance 49 - Server as LMS for AP's
    VRRP Instance 50 - Used for Master Redundancy
    I know I can consolidate 48 and 49. This is a holdover from the migration from 3600's to the 7210's. However, my question is do I need a dedicated VRRP for master/redundancy, or can I use instance 49 for both LMS and controller redundancy? Thanks.
    Dave
  • 2.  RE: How many VRRP Instances Needed
    Posted Jul 25, 2017 09:15 PM
    You only need a single instance.
  • 3.  RE: How many VRRP Instances Needed
    Posted Jul 25, 2017 09:42 PM
    Ok. I thought so, but wanted to confirm. How difficult is it to change the VRRP instance that the master/standby uses? Can I just change the Master VRRP Instance ID, or is there more to it?
  • 4.  RE: How many VRRP Instances Needed
    Posted Jul 25, 2017 10:04 PM
    It could be tricky, because the master is determined by who has control of what vrrp.  If you switch the master redundancy to another vrrp, you might have "split brain".
  • 5.  RE: How many VRRP Instances Needed
    Posted Jul 25, 2017 11:15 PM
    Understood. So the best way is to remove master redundancy and then rebuild I assume.
    From the standby :
     master-redundancy
    (config-master-redundancy)#no master-vrrp
    (config-master-redundancy)#no peer-ip-address
    Then, repeat above on master. Once redundancy is removed, rebuild with new VRRP ID.
  • 6.  RE: How many VRRP Instances Needed
    Posted Jul 25, 2017 11:39 PM
    Backup the flash on your master, FIRST...
