How often do you restart your controller ?
  • 1.  How often do you restart your controller ?
    Posted Feb 27, 2017 05:34 AM
    Hello community,
    I've got a quick question,
    How often do you restart your controller? and your access points ?
    After a lot of change, do you advise to do it?
    Many thanks in advance.
  • 2.  RE: How often do you restart your controller ?
    Posted Feb 27, 2017 05:36 AM
    Hi Michael,
    I do it once a year, but I think it is recommended to do it a couple of times per year. It is also a good practice to check the resiliency :)
    Regards
    Borja
  • 3.  RE: How often do you restart your controller ?
    Posted Feb 27, 2017 05:38 AM
    Thanks Borja for your answer.
    me too, i think it's a good practice but I'm curious how often the community do it.
    do you restart the controller and the AP ? or just the controller ?
  • 4.  RE: How often do you restart your controller ?
    Posted Feb 27, 2017 06:17 AM
    Absolutely!
    Only the controller. I only restart the AP's when I upgrade.
    Cheers
    Borja
  • 5.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 04:09 AM
    I recently logged on to a system that had been managed by another partner. The uptime of the controllers was roughly 2 years 1 month and nothing complained ;)
    That said - unless you upgrade there shouldn't be a need to schedule a reboot of your controllers. If you have to do that - something is wrong - either in your design (ie. too high load) or the software version you're using has bugs..
  • 6.  RE: How often do you restart your controller ?
    MVP EXPERT
    Posted Feb 28, 2017 04:15 AM
    I find it all depends on our customer, most of them are usually never over a year due to either planned maintenance or upgrades!
    My personal lab controller is a different story, that gets rebooted almost every couple of days! :D
  • 7.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 04:17 AM
    Hello Jsolb,
    Many thanks for your quick reply...
    i'm going to upgrade the controller with the lastest version... i guess my version has some bugs because the ap reboot by itself ...
    But it's a good thinks to get feedback !
    The controller that you told to us, did he get a lot of change few weeks ago ?
    my controller get a lot of changes ( number of channel changed, rates, etc... ) in order to improve the settings....
    That why this question comes to my mind :)
    have a good day
  • 8.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 04:18 AM
  • 9.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 04:27 AM
    When asked to do a healthcheck I start by checking software version and the dashboard to see status quo. Based on those findings I go through the config and document changes I want to do.
    But - I always schedule upgrading/patching and do a new status quo before doing any major changes.
  • 10.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 04:35 AM
    thanks is a very good things to do ! many thanks for your advice
    here, on this setup i guess the "bug" version of the software cause ap tx restarting and cause clients disconnection...
    i've got like some AP's with 240d of uptime and other 3h ... :/
    I know that i need to upgrade the code...
    my question is most about the "routine maintenance"
  • 11.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 04:37 AM
    you're are right !
    i asked to do a Site Survey and to check all the swith port statut in case of duplex missmatch or fcs etc...
    it's a whole audit of the infrastructure
  • 12.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 05:07 AM
    Have fun with that! I always enjoy going through a system and see how others do things. That is - when it's not in a critical troubleshooting scenario ;)
  • 13.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 05:14 AM
    my guys like to do it as well :)
    not a critical scenario... but critical application :)
    thanks ! and yes it's nice or funny to try to get what the other did
  • 14.  RE: How often do you restart your controller ?
    Posted Feb 28, 2017 11:01 AM
    Michael,
    What is your current version and the one your are planning to updagre that fixes the Ap reboots ?  for curiosity do you have a Bug number ?
    We lost couple of lines on the config after saving the config and performing an upgrade from AOS 6.3.1.15 upgrading to .21
    I'd advise to collect a backup before ( as I am sure you already planned to do ) and compare with the config after the upgrade to confirm everything is in place.
    DSP
  • 15.  RE: How often do you restart your controller ?
    Posted Mar 01, 2017 03:19 AM
    my code version is 6.4.2.13
    did you have any feedback about upgrading from this version to the last one ?
    have a good day.
  • 16.  RE: How often do you restart your controller ?
    Posted Mar 01, 2017 07:58 AM
    Hello Michael-dc,
    Check Table 5: Known Issues in ArubaOS 6.4.2.18 RLN
    Nothing specific, if I am honest I haven't work with controllers on that specific versions.
    DSP
  • 17.  RE: How often do you restart your controller ?
    Posted Mar 01, 2017 10:15 AM
    Thanks !
  • 18.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 08:40 AM
    hello,
    first feedback after upgrading the controler to the lastest version : 6.5.1.4
    everything seems to be fine except all my AP 275 won't come up after the upgrade...
    Anyone get this issue ?
  • 19.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 08:49 AM
  • 20.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 08:57 AM
    ok, thanks.
    You recommanded to downgrade to 6.5.1.3 ?
  • 21.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 09:01 AM
    the issue with the AP 275 on 6.5.1.3, the 6.5.1.4 should fix that, see the screenshot
  • 22.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 09:43 AM
    my apologies you are correct the 6.5.1.4  fixed the issue with the 275s
    Symptom: An AP failed to boot. The fix ensures that the AP boots successfully. Scenario: This issue occurred when an AP-275 access point was upgraded to ArubaOS 6.5.1.3.
    what behavior are you currently experiencing with the AP275s ?
  • 23.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 09:55 AM
    the AP's wont come up after the upgrade...
    nothing more than "down" on the interface....
    we are trying the " restart" the AP and probably reset them....
    other idea ?
  • 24.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 10:20 AM
    Do you have console access to the AP?
    Run the following command on the controller :
    Show log system all | include
  • 25.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 10:24 AM
    yes we unmonted one of them...
    but we are unable to get anything for the terminal ( we tested the cable before)
    look like the AP is stuck....
  • 26.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 10:28 AM
    You cant see the boot process ?
    If the controller logs is not showing any errors related to the 275 not coming up or can't see any information when the AP is booting via the console i suggest you open a TAC case
  • 27.  RE: How often do you restart your controller ?
    Posted Mar 14, 2017 10:55 AM
    by resetting the AP it's works now....
