Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
How Primary and Management VLAN can be changed?
This thread has been viewed 24 times
  • 1.  How Primary and Management VLAN can be changed?
    Posted Dec 15, 2022 06:52 PM
    Hey,
    I need to change the Management and Primary VLAN on my switches to VLAN 10; therefore  I have done below configuration
    • Onthe GW
      • VLAN 10
      • Stastic IP address 10.10.10.1
      • Subnet mask 255.255.255.0
      • DHCP enabled:   range 10.10.10.0/24;  GW and DNS 10.10.10.1
      • LAN port: port mode Trunk, Native VLAN 10, Allow 10, 33 (user VLAN)
    • On the Core Switch
      • VLAN 10
      • DHCP enabled
      • Primary and Management enabled
      • Uplink port untagged VLAN 10
      • Downlink prots to access switches  untagged VLAN 10
    • On access switches uplink and downlinks to IAPs untagged to VLAN 10.
    With the mentioned configuration I can see that core all switches and IAPs still get IP address from VLAN10 range for on the default VLAN:
    VLAN | IP Config IP Address Subnet Mask Std Local
    DEFAULT_VLAN | 10.10.10.2  255.255.255.0  no no
    Is there any way to fix this issue, or I have to use default VLAN as the primary or management or for both?
  • 2.  RE: How Primary and Management VLAN can be changed?
    MVP GURU
    Posted Dec 16, 2022 10:05 AM
    Hi, you wrote "on my switches", what switches? which families?
    Then you wrote "management", "default" and "primary" VLAN...can you clarify what you mean when you refer to those names?
  • 3.  RE: How Primary and Management VLAN can be changed?
    Posted Dec 20, 2022 03:51 AM
    If you have VLAN10 untagged from your core to APs/Access Switches, unless you configure those switches as well to have untagged VLAN 10, they will use the default VLAN. An untagged port does not carry a VLAN-ID, and depending on your configuration that is not needed either.
    So to 'fix' this, configure the port on your Access switch facing your core to VLAN10 / untagged, and set an IP (or dhcp client) on VLAN 10 on those switches.
    Hope this is the correct answer, because your explanation is somewhat ambiguous.
