If you have VLAN10 untagged from your core to APs/Access Switches, unless you configure those switches as well to have untagged VLAN 10, they will use the default VLAN. An untagged port does not carry a VLAN-ID, and depending on your configuration that is not needed either.
So to 'fix' this, configure the port on your Access switch facing your core to VLAN10 / untagged, and set an IP (or dhcp client) on VLAN 10 on those switches.
Hope this is the correct answer, because your explanation is somewhat ambiguous.
Original Message:
Sent: Dec 15, 2022 06:51 PM
Subject: How Primary and Management VLAN can be changed?
Hey,
I need to change the Management and Primary VLAN on my switches to VLAN 10; therefore I have done below configuration
- Onthe GW
- VLAN 10
- Stastic IP address 10.10.10.1
- Subnet mask 255.255.255.0
- DHCP enabled: range 10.10.10.0/24; GW and DNS 10.10.10.1
- LAN port: port mode Trunk, Native VLAN 10, Allow 10, 33 (user VLAN)
- On the Core Switch
- VLAN 10
- DHCP enabled
- Primary and Management enabled
- Uplink port untagged VLAN 10
- Downlink prots to access switches untagged VLAN 10
- On access switches uplink and downlinks to IAPs untagged to VLAN 10.
With the mentioned configuration I can see that core all switches and IAPs still get IP address from VLAN10 range for on the default VLAN:
VLAN | IP Config IP Address Subnet Mask Std Local
DEFAULT_VLAN | 10.10.10.2 255.255.255.0 no no
Is there any way to fix this issue, or I have to use default VLAN as the primary or management or for both?
