How the MSK is generated from the EAP process?
  • 1.  How the MSK is generated from the EAP process?
    Posted Dec 21, 2015 09:16 PM
    Hi guys,
    Could someone tell me how the MSK is generated from the EAP process?
    I know that they use the first 256 bits to be the PMK, but I really don't know during the EAP process how the MSK is generated.
  • 2.  RE: How the MSK is generated from the EAP process?
    Posted Dec 21, 2015 09:19 PM
     MSK = MasterReceiveKey + MasterSendKey + 32 bytes zeroes (padding)
  • 3.  RE: How the MSK is generated from the EAP process?
    Posted Dec 21, 2015 09:23 PM
    Hi Tim,
    You mean in EAP-tls both side have the same PMK, right ?
    Because PMK = the first 256 bits of MSK
  • 4.  RE: How the MSK is generated from the EAP process?
    Posted Dec 21, 2015 09:33 PM
    Not sure I'm following you.
    Here is the MSK deriviation for EAP-TLS from the standard.
    RFC 5216            EAP-TLS Authentication Protocol           March 2008
                |                       | pre_master_secret       |
          server|                       |                         | client
          Random|                       V                         | Random
                +---->|             master_secret           |<----+
                |     |               (TMS)                 |     |
                V                       V                         V
          |                         key_block                       |
          |                   label == "key expansion"              |
            | client  | server  | client  | server  | client  | server
            | MAC     | MAC     | write   | write   | IV      | IV
            V         V         V         V         V         V
                      Figure 1 - TLS [RFC4346] Key Hierarchy
       EAP-TLS derives exported keying material and parameters as follows:
       Key_Material = TLS-PRF-128(master_secret, "client EAP encryption",
                         client.random || server.random)
       MSK          = Key_Material(0,63)
       EMSK         = Key_Material(64,127)
       IV           = TLS-PRF-64("", "client EAP encryption",
       Enc-RECV-Key = MSK(0,31) = Peer to Authenticator Encryption Key
                      (MS-MPPE-Recv-Key in [RFC2548]).  Also known as the
                      PMK in [IEEE-802.11].
       Enc-SEND-Key = MSK(32,63) = Authenticator to Peer Encryption Key
                      (MS-MPPE-Send-Key in [RFC2548])
       RECV-IV      = IV(0,31) = Peer to Authenticator Initialization Vector
       SEND-IV      = IV(32,63) = Authenticator to Peer Initialization
                                  Vector
       Session-Id   = 0x0D || client.random || server.random
  • 5.  RE: How the MSK is generated from the EAP process?
    Posted Dec 21, 2015 09:40 PM
    Thanks, I may have to look into it deeply
