How to access new IAP-205H-RW in GUI?
  • 1.  How to access new IAP-205H-RW in GUI?
    Posted Aug 28, 2015 01:08 AM
    IAP-205H was powered via PoE switch. I access it via instant wifi ssid unfortunately can't connet via GUI (172.31.98.1 or instant.arubanetworks.com) and error displayed "webpage is not available".
  • 2.  RE: How to access new IAP-205H-RW in GUI?
    Posted Aug 28, 2015 01:47 AM
    Reset it to factory default and try. BTW, are you joining this new IAP to an existing cluster ? if so, map this new IAP to a new VLAN ( other than existing cluster VLAN ), it should work.
    Usually you should be able to take GUI with Instant SSID.
    Please feel free for any further help on this.
  • 3.  RE: How to access new IAP-205H-RW in GUI?
    Posted Aug 30, 2015 04:27 PM
    I tried to set it in factorty default unfortunately can't access it.
    My set up is only stand alone AP connected to PoE switch and the objective is to access the AP via GUI only.
  • 4.  RE: How to access new IAP-205H-RW in GUI?
    Posted Aug 30, 2015 04:55 PM
    Are you supplying dhcp?
  • 5.  RE: How to access new IAP-205H-RW in GUI?
    Posted Aug 30, 2015 05:14 PM
    No. I just used Default IP address 172.31.98.1 for web access.
    Network Set UP:
    PoE Switch < ----- > IAP 205-H < ----- > Laptop
                                  (172.31.98.1)           (172.31.98.43)
    Test Procedure:
    1.Laptop connect to instant SSID.
    2.Web access via 172.31.98.1 or it will be redirected to https://instant.arubanetworks.com:4343.
    3.Webpage is not available
    By the way I tried to two AP's in this same network set up and I successfully accessed the AP (IAP-205 & IAP-215) via GUI. Only in IAP-205H encountered this error and GUI access is not successful.
  • 6.  RE: How to access new IAP-205H-RW in GUI?
    Posted Sep 12, 2015 10:45 AM
    did you try different browsers, clear browser cache, ...?
  • 7.  RE: How to access new IAP-205H-RW in GUI?
    Posted Sep 13, 2015 10:49 PM
    Yes, tried that (Different browser, clear cachec, pc restart).
    Basically this maybe related on the software version of the AP.
  • 8.  RE: How to access new IAP-205H-RW in GUI?
    Posted Sep 13, 2015 11:00 PM
    Please try supplying dhcp to the AP.
  • 9.  RE: How to access new IAP-205H-RW in GUI?
    Posted Aug 30, 2016 08:59 AM
    Colin, when you say "Please try supplying dhcp to the AP", how would you do that if you cannot asccess the GUI, and where would the AP gets it's dhcp address from?
