Wired Intelligent Edge
How to access the web based management console of HP Procurve 2920 J9726A and J9729A ?
  • 1.  How to access the web based management console of HP Procurve 2920 J9726A and J9729A ?
    Posted Mar 23, 2015 11:34 PM
    People,
    I just bought the second hand HP Procurve 2920 J9726A and J9729A (POE) switch and I wonder if anyone here can assist me how to access the web based management console using my laptop and crossover cable ?
    http://h17007.www1.hp.com/us/en/products/switches/HP_2920_Switch_Series/index.aspx#J9726A
    what's the default username and password if possible.
    #EWS
  • 2.  RE: How to access the web based management console of HP Procurve 2920 J9726A and J9729A ?
    Posted Mar 24, 2015 07:33 AM
    If the switch has been reset to factory defaults by the previous owner there should be no username and password necessary for console and web access. The default config is for the switch to obtain an IP address by DHCP, so if you don't have a DHCP server then you will not be able to use web access. Then you will need to connect with a console cable and set an IP address manually.
    If you need to reset the switch to factory defaults, here is the procedure:
    1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
    2. Continue to press the Clear button while releasing the Reset button.
    3. When the Test LED begins to blink, release the Clear button. It takes approximately 25 seconds before the Test LED will begin to blink.
    The switch will then complete its boot process and begin operating with its configuration restored to the factory default settings.
  • 3.  RE: How to access the web based management console of HP Procurve 2920 J9726A and J9729A ?
    Posted Mar 24, 2015 08:55 PM
    Thanks Terje.
    so in this case how to know if the switch go t the IP from the DHCP ?
