last person joined: 7 hours ago
How to activate IAP-275 once it's moved to a controller
  • 1.  How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 01:37 PM
    I converted an IAP-275 from and instant AP to a mobility controller with all of my other APs (225s).  Now that I have it in the controller, it is flagged with 2I and I cannont seem to get the radios enabled on it.
  • 2.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 01:49 PM
    On the commandline of the controller, type "show log system 50" to see if you can get a clue why the AP would not come up.
  • 3.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 01:54 PM
    I am unable to get it to respond to ssh now that it is on the controller.
  • 4.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 02:33 PM
    You should SSH into the controller to get that log..
  • 5.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 03:38 PM
    ok here is what it shows but I am not sure what it means
  • 6.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 03:52 PM
    Is there a firewall between that AP and the controller?
  • 7.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 04:36 PM
    No it is not.
  • 8.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 04:44 PM
    and i verified it is not a licensing issue.
  • 9.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 05:07 PM
    Is it in the same ap-group as other access points?
  • 10.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 05:10 PM
    Yes it is but they are models AP-225.  This one is a AP-275.
  • 11.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 05:13 PM
    You should reach out to TAC.  They will have to determine if this is a misconfiguration or a bug.
  • 12.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 05:14 PM
    How do I get in touch with TAC?
  • 13.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 05:29 PM
  • 14.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 08, 2017 05:39 PM
    Thank you.  When we come to find out why I am having this issue I will post again so others will know if they are having the same issue what the resolution was.
  • 15.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 09, 2017 03:09 PM
    Are you using a PoE+ switch or PoE+ injector? (802.3at)
    If its on a PoE+ switch, is LLDP enabled on the switch?
    Look at "show ap debug system-status | include POE" to see if the radios are disabled because of lack of PoE+
  • 16.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 10, 2017 10:38 AM
    In Addition to what Arjan Suggested about checking the power, Could you also check the Country codes on both the devices?
    On the controller :
    # show country
    On the IAP :
    show country-codes
  • 17.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 11, 2017 11:10 AM
    I checked country codes and both say US.  I enabled LLDP and got no change.
    I tried another IAP-275 to make sure I didn't have a faulty device and got the same results.  So that leads me to believe I am doing something wrong.
    Once I convert it to the mobility controller, I find it and select provision.
    In the provision screen, I drop it in the right AP Group, then scroll to the bottom to rename the AP.  Unlike the AP-225, there are extra lines that I wonder if I need to add anything there.  Here is a screen shot of those extra lines:
    Here is the W-AP225(I am having no issue with these)
    W-AP225W-AP225I cannot get the radios enabled on the IAP-275IAP-275IAP-275
  • 18.  RE: How to activate IAP-275 once it's moved to a controller
    Posted Dec 12, 2017 05:31 PM
    So this turned out to be a power deficientcy.  I had to log into the cisco switch to adjust the power output.  The default power on the cisco switch is set to 15.4 watts and 23.5 watts is needed.  I adjusted the power to the max (30 watts) and it solved the issue.
