how to add Access point to controller
This thread has been viewed 16 times
  • 1.  how to add Access point to controller
    Posted Mar 23, 2016 09:53 AM
    hi everyone i'm having a trouble adding AP on controller, can you please help me,
    yesterday i have added some AP, but i those ap are not up now and new ap also not able to add
    i can ping all AP from controller those previous AP,
    but i'm missing somewhere
    can you please help to
    i would like to invite anyone teamviewer plz, i have been trying to make it happen since yesterday still same
    teamviewer ID   502 551 801
                   PWD:  5932
    i will be awainting
  • 2.  RE: how to add Access point to controller
    Posted Mar 23, 2016 09:57 AM
    Are they brand new APs or used?
    If used, did you purge them?
    Do you have CPSEC enabled?
    How are you doing controller discovery?
  • 3.  RE: how to add Access point to controller
    Posted Mar 23, 2016 10:04 AM
    it is brand new AP 205,
    i have total 150 AP need to add on controller. but unable to do so
    could you please try to connect team viewer plz
    thanks,
  • 4.  RE: how to add Access point to controller
    Posted Mar 23, 2016 10:31 AM
    This is not really a suport forum for people to jump on to help, if they can great, but if you need something fast, I would open a TAC case. You still hadn't answered the other questions above (AP discovery, CPSec on or off, etc). My recommendation would be to open a TAC case and work with them to assist you.
  • 5.  RE: how to add Access point to controller
    Posted Mar 23, 2016 11:27 AM
                   PWD:  5932
    i will be awainting
     I would SSH into the controller and type "show audit-trail" to see if anything was changed between yesterday and today", so that you can perhaps get an idea what is wrong...
  • 6.  RE: how to add Access point to controller
    Posted Mar 26, 2016 05:41 AM
    thanks Colin Joseph
    now i have added 119 AP, i still have to add 31 more, i will go site later on then will double check.
    but the problem i was experiencing the AP is too much heat, even if you touch by your hand you feel very hot.
    is there any solution to reduce heat on AP?
    thanks.
  • 7.  RE: how to add Access point to controller
    Posted Mar 26, 2016 06:38 AM
    You cannot reduce the heat on an access point, no.
  • 8.  RE: how to add Access point to controller
    Posted Mar 27, 2016 03:01 AM
    thanks Colin Joseph
    but it seems not normal case, it is too much heat, are you sure  we can't fine tune to reduce heat
    thanks!!
    Regard
    Mr. Tej Bahadur
  • 9.  RE: how to add Access point to controller
    Posted Mar 27, 2016 03:52 AM
    It's a common concern as they do get warm, the back of the AP is designed to be a heat sink (it's a very common question). However, it's well within spec. If you want to get an IR camera to shoot a picture and post it, we can tell you if it's within spec. I don't recall the temp off the top of my head at 2AM, but I can find out on Monday.
