Network Management
How to add Aruba S2500 to Airwave?
  • 1.  How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 10:34 AM
    Hi All,
    I'm just playing around with Airwave and I'm having issues adding a Aruba S2500 switch... Can anyone point me in the right direction please?
    I've tried adding the device like I would a controller and have tripple checked that the community, IP, ports, etc are correct but I'm still getting SNMP Get failed messages..
    Airwave 8.0.0
    Switch AOS 7.2.2
    Cheers
    James
  • 2.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 10:45 AM
    Should be nothing special  James.  I've got 8.0 monitoring switches without problem.    Sounds as though you've done the basic troubleshooting; checking IP and SNMP community string.
    Can you try to do an SNMP Walk from AirWave?
  • 3.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 11:00 AM
    SNMP walk is failing like so... Not sure if I'm using the correct syntax/switch at the end...
    [root@localhost mercury]# s2w 192.168.254.249 aruba .1
    Timeout: No Response from 192.168.254.249
    and I'm using v2 as you'll see..
    I'm no Airwave expert by the way..... Here's what I've done to attempt to add the switch...
    On Airwave:
    Added a new device via Device Setup > Add > Aruba Device > Add. Added the IP of the switch and set the SNMP community to aruba.
    On the switch:
    (S2500-24P-1) (config) #snmp-server community aruba
    (S2500-24P-1) (config) #snmp-server host 192.168.254.9 version 2c aruba
    (S2500-24P-1) (config) #write me
    Airwave and the switch are on the same VLAN.. In fact Airwave is patched into the switch.
    Cheers
    James
  • 4.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 10:49 AM
    ...also are you doing v2 or v3?
  • 5.  RE: How to add Aruba S2500 to Airwave?
  • 6.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 11:27 AM
    Hi Tim, I saw that 70 page document.. It could be more useful...
    In particular this bit stands out..
    Minimum Configuration
    AMP will be able to communicate with your MAS device if you configure the switch using the QuickStart Wizard from
    the CLI.
    So if I didn't configure it using the cli quickstart wizard it wont work?
    I'm still none the wiser if I should use SNMP v2 or 3? Or what I've done wrong...
  • 7.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 11:32 AM
    I would use v2c just to see if you can get it up and running, then potentially move to v3 for security reasons.
  • 8.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 11:37 AM
    I've been using v2 as I described but have encountered issues....
    Think I'll speak to TAC.
  • 9.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 11:47 AM
    James,
    There was an issue in 7.2 (can't recall off the top of my head which release it was resolved in) where SNMP may not respond due to a bug. Try restarting the process then re-running the SNMP walk.
    process restart snmpd
    Best regards,
    Madani
  • 10.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 12:01 PM
    Hey, thanks for the tip. I tried that but still no luck doing SNMP walk..
    Also when running NMAP from Airwave agains the switch should it show UDP 161 as open??
  • 11.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 25, 2014 02:30 PM
    Does your switch multiple IPs?  Are you hitting the switch ip (controller-ip in config)?
    show switch ip
  • 12.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 26, 2014 04:22 AM
    Only 1 IP..
    (S2500-24P-1) #show switch ip
    Switch IP Address: 192.168.254.249
    Switch IP is configured to be Vlan Interface: 254
    Also I upgrade the switch to 7.3.2.0 as there was a mention of SNMP issues with a version on 7.2, still getting SNMP get failed.
    I'll continue to investigate for a bit.. It's the last day of my current job but I'd kinda like to get this working!
  • 13.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 26, 2014 07:21 AM
    jrwhitehead,
    If you have root access to airwave attempt to execute the following:
    s2w <ip address of switch> <community string> wlsxUserTable –On
     That will see if Airwave even has connectivity to the switch.  If you get an error, that might give you a clue what is going on.
  • 14.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 26, 2014 09:38 AM
    James,
    The switch and Airwave can ping each other right?
    I saw your command snippet for SNMP, that should be all you need but just in case can you private message me your config?
    M.
  • 15.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 26, 2014 10:53 AM
    Hi Colin,
    The s2w fails..
    [root@localhost mercury]# s2w 192.168.254.249 aruba wlsxUserTable –On
    There is network connectivity between Airwave and the switch. The management IP are on the same VLAN and Airwave is patched into an access port on that VLAN on the switch in question..
    Will message my config to you madjali.
    Cheers
    James
  • 16.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 26, 2014 12:29 PM
    James,
    Reviewing your config...this should not be there:
    no snmp-server
    Re-enable that.
    Best regards,
    Madani
  • 17.  RE: How to add Aruba S2500 to Airwave?
    Posted Jun 27, 2014 07:14 AM
    Ahh! That'll be it then!
    Thanks.
