How to add IAP 303 in IAP 103 cluster?
  • 1.  How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 03:17 AM
    We are having 7 numbers of IAP 103 with FW 6.5.4.12
    Now we procured 6 numbers of IAP 303.
    How to add this new IAP 303 to the existing cluster with IAP 103?
  • 2.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 04:05 AM
    You will not be able to, the latest released supported by IAP103 is Instant 4.2
    An IAP303 requires a minimum firmware version of 8.3. Due to the version mismatches these will not be part of the same IAP cluster.
    https://www.arubanetworks.com/en-gb/support-services/end-of-life/
  • 3.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 05:13 AM
    What can I do?
    Now I am having 6 numbers of IAP 303 with me.
    Is it possible to add this IAPs as standalone APs?
    In addition to this we are already having 12 Nos of IAP92. But the limitation with IAP92 is the cluster size (max 16). These IAPs are running in a separate vlan.
    Is it good have a Wireless controller for these IAPs
    IAP 92 - 12
    IAP 103 - 7
    IAP 303 - 6
  • 4.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 05:56 AM
    You can create a separate cluster with the IAP303. I would use this in a separate RF domain such as a different building. If not you will need to consider upgrading/replacing the IAP103 with a 8.3x supported IAP.
  • 5.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 06:02 AM
    Can we go for a aruba wireless controller to manage the IAP 92, IAP 103 and IAP 303?
  • 6.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 06:06 AM
    You certainly can however you will need to make sure that each AP supports the AOS version as well. If you take a look at the EOL URL previously provided you can see that the AP92 will only support up to ArubaOS 8.2 and your AP303 requires ArubaOS 8.3 at a minimum.
  • 7.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 06:48 AM
    Yes
    IAP 92 will not support the latest AOS like 8.3 as you mentioned.
    For IAP 103 I have to check.
    Is it possible to Upgrade the IAP 103 from Instant 6.5.4.12.x.x.x to Instant 8.3.x.x
    or vice-versa?
  • 8.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 06:56 AM
    No. The datasheets will provide you with the minimum requirement of
    firmware for an IAP and the EOL/EOS URL will provide you with the latest
    supported firmware if announced.
  • 9.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 07:05 AM
    IAP 303 - Minimum OS - ArubaOS 6.5.1.0, 8.1.0.0 and Aruba InstantOS 4.3.1.0
    IAP 103 - Minimum OS - ArubaOS 6.4.0.0 and Aruba InstantOS 4.1.0.0
  • 10.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 07:09 AM
    Take a look at the below, IAP303 minimum is 8.3
    https://www.arubanetworks.com/assets/ds/DS_AP303Series.pdf
  • 11.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 07:15 AM
    Yes.
    Now I am totally confused.
    What I can do?
    What is the solution?
    WLC?
  • 12.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 07:17 AM
    What is your main objective or reasoning for obtaining the 303's?
  • 13.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 01, 2019 07:27 AM
    No specific reason. Just to extend the Wi-Fi facilty in our campus.
  • 14.  RE: How to add IAP 303 in IAP 103 cluster?
    MVP EXPERT
    Posted Apr 01, 2019 07:41 AM
    If this is to be a Multi-Building Layout within a Contiguous RF Domain then Aruba recommends that you deploy the IAPs as a single cluster.
    If this is a Multi-Building Layout with a Non-Continuous RF Domain then each building could have its own single cluster.
    So from your point of view you will have a split cluster and 2 location of management if you have a 103/303 set of clusters. If these are sharing the same RF domain then there will be an increase in contention for the medium as well.
  • 15.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 03, 2019 06:49 AM
    I am really sorry for the late reply. Officail commitments...
    I am not aware that of RF Domain.
    The IAP are not in single building. Located in different buildings
    Can plz forward link about RF Domain???
  • 16.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 09, 2019 07:24 PM
    In this conversation "RF Domain" refers to your expectations for overlapping coverage.
    If you need to have one radio environment (RF Domain) with all of your APs in overlapping cells, then you have a bit of a problem.
    If you can make seperate areas, for instance one where the AP92 operate, another where the AP103 operate and a third where the AP303 operate you'll have the most work to do managing them, but the easiest time managing the coverage and client experience.
    Knowing nothing of your actual deployment or radio environment (so my advice will almost certainly be flawed) here's what I would do:
    Manage all three AP families separately in patches - all of each type near one another on one area and the next type in the next area etc. Then start replacing the oldest APs with the same model as the newest until that oldest model is gone.
    The adjacent but separate clusters will mean that clients will have to roam oddly, but the clients I have experisnce with seem to handle it well enough in my environment.
    The only reason I would suggest this is on the assumption that you'll get budget to replace older hardware - otherwise you're just going to have too many clusters to manage over time.
  • 17.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 09, 2019 11:53 PM
    Can we manage the IAP 103 and IAP 303 with a controller?
  • 18.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 10, 2019 02:05 AM
    yes you can manage them with a controller.
  • 19.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 10, 2019 02:19 AM
    Can you suggest a model?
  • 20.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted Apr 10, 2019 03:57 PM
    check the datasheet
    The 7005/7008 can handle up to 16 APs, the 7010 will go up to 32
    At this point you should really go talk to your support team (Partner or Aruba Sales) to go over your needs and future plans.
  • 21.  RE: How to add IAP 303 in IAP 103 cluster?
    Posted May 09, 2019 12:35 AM
    Thank you very much for your contribution its really Helpfull for me.
