How to add multiple Device subnets to a Device Group
  • 1.  How to add multiple Device subnets to a Device Group
    Posted Dec 09, 2015 05:31 PM
    I have many device subnets that need to be added to a Device Group. Do I need to create separate entries for each? ... this seems to be the only way.
    I was able to create a Regex to support the multiple subnets [under Device Groups], but in defining a Device, you can only enter a single ip address or a single subnet. How to add multiple subnets? ..or use a regex to define the device scope.
  • 2.  RE: How to add multiple Device subnets to a Device Group
    Posted Dec 26, 2015 09:36 AM
    the help states: You can use a hyphen to indicate the range of device IP addresses following the format a.b.c.d-e. For example, 192.168.1.1-20.
    you might be able to work with that in the third octet although im not very sure that will work.
    the alternative is with exporting, editing xml and importing devices and add more quickly like that.
