How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
  • 1.  How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 22, 2016 03:22 AM
  • 2.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    MVP EXPERT
    Posted Jul 22, 2016 04:13 AM
    Have you considered using MAC authentication to bypass the Captive Portal for certain devices? If you let us know a bit more about your deployment (IAP, controller based etc) we might be able to provide some instructions.
    ** EDIT **
    Might be worth reading this...
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Captive-portal-and-MAC-authentication/td-p/70320
  • 3.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 25, 2016 01:01 AM
    May I know how to do MAC authentication
  • 4.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 25, 2016 01:07 AM
    here one more complication is there, this printer should be accessed only by 4 user not by all user connected to guest network.
  • 5.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 22, 2016 08:39 AM
    You have not given us alot of details.  How you would add a printer of course depends on the printer capabilities and if the printer is even routable to the guest network.
  • 6.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 25, 2016 12:51 AM
    Both printer and users are in guest network. Guest network using captive portal for authentication.
    Printer is getting IP address and pingable from other devices but user not able to print document.
  • 7.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 22, 2016 09:38 AM
    Also:
    - How are your guest users authenticating today?
    - Do you have ClearPass?
  • 8.  RE: How to add printer to Guest Wi-Fi. %28guest connects through captive portal%29
    Posted Jul 25, 2016 12:53 AM
    Guest network uses captive portal authentication. both the user and printer are in same network (guest  network). Printer model is
    Make: HP
    Model: Clolor Laser Jet MFP M277dw.
    Printer is getting the IP address but user not able to print the document. even user can able to ping the printer.
