How to allow 40MHz width in ARUBA 135
  • 1.  How to allow 40MHz width in ARUBA 135
    Posted May 07, 2015 12:50 AM
    I am having ARUBA 135 series APs.   My clients will support 40MHz channel width in 2.4 GHz. How to allow 40MHz channel width in ARUBA 135 APs?
     Please help out with this query
  • 2.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 07, 2015 01:38 AM
    HI,
    You have to enable wide channel support feature as shown in the snapshot. here you have select 2.4 GHz as Wide channel support to meet your requirement
    Please feel free if the above is not solved your issue.
  • 3.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 07, 2015 03:50 AM
    I am having some issue with ARUBA 135
    Is it possible to call you and explain the issue.
  • 4.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 07, 2015 06:10 AM
    Please share your issue details. I surely help you on resolving the issue.
  • 5.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 07, 2015 07:21 AM
    40 MHz channels are NOT recommended for the 2.4 GHz band.
    Tim
  • 6.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 07, 2015 09:06 AM
    Hi Dhanraj,
    I had used 20 MHz channels only earlier. Even though it was not
    working.
    Please suggest me what needs to be done to increase the
    speed of ARUBA 135 APs as I am getting only 10 MBPS from all 6 APs. When 5
    - 10 clients are there in the depot all the clients are transferring at 2
    MBPS. But when 60 clients are in depot then most of the clients are below
    100 KBPS only. Please suggest me so that each client should transfer at at
    least 500 KBPS.
  • 7.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 08, 2015 07:04 AM
    I suggest looking at your RF environment if you are not getting the speeds you desire. As Tim pointed out, using 40Mhz on 2.4Ghz is not recommended.
  • 8.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 08, 2015 07:36 AM
    lease suggest what re the chnages to be done in RF?
  • 9.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 08, 2015 07:44 AM
    Without knowing you're environment it is difficult to suggest changes.
    I suggest opening a case with TAC as they can look at your whole network.
  • 10.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 06:28 AM
    Hi all,
     What is the max speed that the ARUBA 135 AP can receive the data from client through wireless and transmit the dtaa to server through LAN?
     Please share me the MAx and Min values of speed?
  • 11.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 06:29 AM
    you said the 40 MHz channels are not recomended for 2.4GHz. In which case/ Band these 40 MHz channel width can be used?
  • 12.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 06:54 AM
    The speed of traffic through an AP135 depends on client capability, congestion, and a number of other factors.  If your client speed is 100k, it is low.
    Are you running a controller-based or instant network?
    How long has it been installed?
    What kinds of clients are connected?
    How many SSIDs do you have configured?
  • 13.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 07:18 AM
    We are having 21 APs in 3 locations.
    1st location   -   6 APs             SSID   -    CD1                           Clients   -   60
    2nd location  -   7 APs             SSID   -    ISBT                           Clients  -    90
    3rd location   -  6 APs             SSID   -    BAIRAGARH              Clients  -   60
                                        All these 3 locations are connected through P2P devices (intranet). The 1st location is having a controller where all the changes will take through this controller for remaining 2 locations.
                           We had configured 1 SSID in one location. The clients will support max of 16mbps each.
                                  We are using Digital video recoder in bus which will store the data. This DVR will have an Wi-Fi which will connect to ARUBA AP as soon as it comes to the depot and start transfer the data.
  • 14.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 07:27 AM
    What operating system is the digital video recorder and what encryption is used to connect to the wireless?
  • 15.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 07:40 AM
      The DVR OS is LInux. But the DVR is having a LAN port and Wi - Fi device is also having a LAN port. The DVR and Wi-Fi device will cobnnect through wire. And the Wi-Fi will connect to AP and transfer the data to server. The Wi-Fi will transfer a max data of 16Mbps.
              Now the issue is when 5- 10 clients are connceted to the APs they are transferring at higher rates. But when 60 clients connect to 6 APs most of the clients are transferring less than 100 Kbps. I am suspecting some issue from AP side as the clients are transferring data at higher speed when less number of clients are connected.
      Please find the screen shots of Wi-Fi router
  • 16.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 07:43 AM
     We are using WPA2 encryption
  • 17.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 08:02 AM
    Are you using an Aruba controller to configure the AP135s, or is this an IAP (Instant) deployment?
  • 18.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 08:08 AM
     We had made 1 ARUBA IAP as virtual controller so that it will pass on the changes to other APs.
  • 19.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 11, 2015 09:17 AM
  • 20.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 02:25 AM
    I dont see much improvement even after changing the Broadcast filtring to ALL.   These 6 APs are installed side by side with a distance of 10 meters between each AP. I ma using Channel 1 for 2 APs,Channel 6 for 2 APs and Channel 11 for 2 APs.
          Please suggest me how to increase the throughput and all the clients should transfer atleast by 8 Mbps.
           What is max data rate that AP can receive through Wireless and transfer then through LAN to the server?
  • 21.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 07:50 AM
    How high are these access points mounted?  10 meters is too close in an open space.  20 meters would be better.
  • 22.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 08:48 AM
        These APs are mounted to a wall at 4 meters height. But the radius of depot is less that is the reason we had installed 10 meters for each AP. How to oincrease the speed of AP as I am only receiving only 8 - 10 MBPS ( 64 - 80 Mbps)  at server end.
                  But we rae having 60 clients which are capable of transferring 2MBPS (16Mbps) each. Then I should receive more speed at server end right?
                     We are having 6 APs and 60 Clients in the depot. We need more speed as we need to download a data of 700 GB  within 10 Hours.
                      Each AP is transferring only 1.5 MBPS (12Mbps). But the AP will support 150 Mbps.
               Please suggest how to increase the speed. Is there any issue with 2.4GHz band and how to configure the channels for APs.  Please suggest
  • 23.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 08:57 AM
    Do you have a screenshot of the channel utilization from the virtual controller?
  • 24.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 09:05 AM
    Hi ,
     Please find the attached screen shot of channel utilization.
  • 25.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 09:23 AM
    You only seem to have high utilization on one access point, so you could have problems there.
    Do you have problems with other clients?
  • 26.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 09:29 AM
          At present there are few clients in the depot. All the clients will connect after 7:30 P.M. Once all the clients enter the depot the speed is getting reduced as some clients are transferring only in KBPS. Is there any limit in 2.4 GHz channels ?
  • 27.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 09:30 AM
    There is no limit by default. You should try to connect a separate client at night to rule out a client issue.
  • 28.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 09:40 AM
     There is no issue with the client. Even when 10 clients are connected I am receiving 10MBPS (100Mbps) data at server end and even 60 clients are conncted I am receiving only 10MBPS (100Mbps) data. there is some issue with the APs.
             Please find the attached acreen shot in which we had received 2 TB data from last 7 days. On an average we are receiving 300 - 350 GB data per day. But our clients support 2MBPS (16Mbps). Then we should receive 700 GB data per day because each bus will have 13 - 14 GB data. We are having 60 clients. Please suggest me as there is some configuration issue / some other issue with AP.
  • 29.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 10:10 AM
    That data rate and the data transferred does not explain your issues.
    Do you have a floor plan that shows where your access points are mounted?
    - You have access points mounted 3 meters on the wall.  They should be mounted on a ceiling, or if they are mounted on the wall, they need to be pointing down.  If they are not pointing down, your clients on the ground, especially right under the access point will have a problem connecting, due to the pattern.
    - You have the transmit power on your access points at 21, which is too high, since you have them mounted at every 20 meters.  You should change the ARM maximum Transmit to 18 or 15 and the ARM minimum Transmit to 12:  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/ARM/Configuring_ARM-Features.htm
    If you have the transmit power too high, that will cause interference with other access points and that will cause or contribute to your performance issue.  If you only have a few users, they might get good performance, but as more users connect and they add to the interference, your throughtput will go down.  Having access points at the highest power will also cause roaming issues.  Also you have an access point that has high utilization (78) that you might have to look at see if there is other interference like a Microwave or other wireless devices that could be causing your issue.
    If you can, make sure that ARM Client Match is turned OFF (http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/ARM/Configuring_ARM-Features.htm) and you are running Instant 4.1.1.3 or higher to avoid any issues.
  • 30.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 10:27 AM
    Hi ,
     We had pointed APs towrads down itself. The client match is disabled earlier itself. Which should I use for band steering? At present we are only having 2.4GHz clients.
       Please share me the latest firmware.
  • 31.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 13, 2015 11:04 AM
    Please PM me so I can send you a link to it.
  • 32.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 14, 2015 03:24 AM
  • 33.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 14, 2015 03:26 AM
     We are not getting enough speed as we are receiving only 10MBPS at server. Yesterday we had received 310 GB data at server end from 6 APs but we should receive 700 GB atleast in 10 hours.
         Please suggest
  • 34.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 14, 2015 06:23 AM
    If you only have 2.4 GHz clients, the client match setting does not matter.
    Did you try turning down the max power on the access points?
  • 35.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 14, 2015 06:36 AM
     Yes I had tried that also.
  • 36.  RE: How to allow 40MHz width in ARUBA 135
    Posted May 14, 2015 05:36 PM
    Please open a TAC case so they can get the full picture and help you.
  • 37.  RE: How to allow 40MHz width in ARUBA 135
    Posted Jun 11, 2015 05:49 AM
     I am planning to take 5.8 GHz clients. Will IAP 135 support 5.8 GHz clients?
  • 38.  RE: How to allow 40MHz width in ARUBA 135
    Posted Jun 11, 2015 05:50 AM
       Please share me the latest firmware for ARUBA 135
  • 39.  RE: How to allow 40MHz width in ARUBA 135
    Posted Jun 11, 2015 05:51 AM
    mail2mdileep@gmail.com wrote:
    What version of the firmware do you have now?  Did you check for updates?
  • 40.  RE: How to allow 40MHz width in ARUBA 135
    Posted Jun 29, 2015 04:37 PM
    Can we connect an external antenna for ARUBA IAP -135 so that the coverage will increase?
  • 41.  RE: How to allow 40MHz width in ARUBA 135
    Posted Jun 29, 2015 07:00 PM
    You should open a TAC case so that they can review personal technical data that you cannot reveal here.
  • 42.  RE: How to allow 40MHz width in ARUBA 135
    Posted Jun 29, 2015 07:08 PM
    You would need an 134 model as that model supports external antennas
    Pasquale Monardo
    Conseiller Principal Solution R?seaux, Op?ration | Senior Network Solutions Consultant, Operation
    T 514 385-4448 #204 DATAVALET.COM
    5275, chemin Queen-Mary, Montr?al (Qu?bec) H3W 1Y3 Canada
    CE COURRIEL AINSI QUE CES DOCUMENTS JOINTS peuvent contenir des renseignements confidentiels et privil?gi?s. Si vous n'?tes pas le destinataire d?sign?, veuillez nous en informer imm?diatement et effacer toute copie. Merci. THIS EMAIL AND THE DOCUMENTS ATTACHED may contain privileged or confidential information. If the reader of this message is not the intended recipient, please notify the sender immediately and delete the original message. Thank you.
  • 43.  RE: How to allow 40MHz width in ARUBA 135
    Yes.
  • 44.  RE: How to allow 40MHz width in ARUBA 135
