How to assign a VLAN/Subnet to an IAP through IPSec back to the controller ?
  • 1.  How to assign a VLAN/Subnet to an IAP through IPSec back to the controller ?
    Posted Aug 09, 2013 08:29 AM
    (3200-controller) #show  iap table long
    IAP Branch Table
    Name              VC MAC Address     Status  Inner IP        Assigned Subnet  Assigned Vlan  Key                                                 Bid(Subnet Name)
    Instant-C2:12:34  22:33:44:55:66:77  UP      192.168.102.11                                 e38f612f01ba4a5b5ff36a8378f3t3514f7cf3d016dfbf887d
  • 2.  RE: How to assign a VLAN/Subnet to an IAP through IPSec back to the controller ?
    Posted Aug 09, 2013 09:47 AM
    That should be populated based on the VPN and DHCP information in the IAP.
  • 3.  RE: How to assign a VLAN/Subnet to an IAP through IPSec back to the controller ?
    Posted Aug 09, 2013 10:28 AM
    Below modes could achieve the IAP to change the VLAN or subnet. Here is the details.
    IAP DHCP methods
    • Local Mode
    • Centralized L2 Mode
    • Distributed L2 Mode
    • Distributed L3 Mode
    Local Mode:-
    Local mode provides VPN capabilities using inner IP of RAPNG IPsec tunnel.
    Client traffic that has to be forwarded to the corporate destinations is Src-Nated by the Master AP using inner IP of the IPSec tunnel and traffic destined to internet is Src-Nated using localip of the master AP.
    We need to make sure controller`s VPN L2TP pool is routable from upstream.
    Centralized L2 Mode:-
    This method is basically extending corporate VLAN/broadcast domain to remote branches; L2 extension in classic RAP`s.
    DHCP server & the gateway for clients reside in data cent; either controller or upstream router can be
    gateway for clients. Aruba recommends to use an external DHCP server.
    Be default, any client traffic destined to data center will be forwarded by Master AP through IPSec tunnel to the client`s
    gateway in data center.Traffic destined to local destination is Src-NATed using localip of master AP and bridged locally.
    Distributed L2 Mode:-
    Distributed L2 mode is similar to Centralized mode except DHCP server for clients is the Master IAP in the cluster itself.
    Default-gateway for client is still from data center(Master AP through IPSec) which is the L2 extension of corporate VLAN to remote site.
    Major difference is that when the WAN link is down, the IAP will proxy-arp for default-gateway in the data center.
    Clients can renew their lease and receive ip address even when the WAN link is down which is not possible at Centralized L2 mode.
    Distributed L3 Mode:-
    Distributed L3 mode is very similar to site-site IPsec VPN where two VPN endpoints connect individual network over a public network
    Each branch location has the dedicated subnet. Master AP in branch manages the dedicated subnet and acts as DHCP server
    and also as the gateway for clients.
    Client traffic to date center is routed to controller through IPSec and local traffic will be Src-NATed locally.
    Since controller is in datacenter is aware of L3 subnet at each branch and it can redistribute these routes to upstream router using OSP.
    We need to make sure Aruba Instant OS 3.3 are required to support the above ability to do this.
    Hope this helps.
     Thanks!
