How to assign Vlans for different AP group with internet up-link vlan
  • 1.  How to assign Vlans for different AP group with internet up-link vlan
    Posted May 08, 2017 04:41 PM
    I have several AP groups need to assign vlans for each group
    4550(0/0/2-)---L3 switch(1/1/13)-----L2 switch(1/1/1)--AP----Wireless clients
    Controller Uplink -vlan 2222 (Ap vlan asame)
    Core switch -  vlan 858 (tagged in uplink ports  of controller connecting to coreswitch & )
    Internet Uplink -vlan 1002 (IP for wireless clients)
    VAP profile - for eg AP group : Ground floor(vlan 858)
    If the above is like this means where in VAP profile should i need to add vlans 858 & 1002
    Please explain
  • 2.  RE: How to assign Vlans for different AP group with internet up-link vlan
    Posted May 08, 2017 05:36 PM
    What are you using VLAN 858 for?
    Get Outlook for iOS
  • 3.  RE: How to assign Vlans for different AP group with internet up-link vlan
    Posted May 16, 2017 12:26 AM
    We need to configure vlan for floorwise wireless clients
    eg: vlan-851-1st floor,vlan-852-2nd floor is this acheivable ?
  • 4.  RE: How to assign Vlans for different AP group with internet up-link vlan
    Posted May 16, 2017 05:11 AM
    It is achievable, but it creates unintended issues.  If a user roams from the first floor to the second floor, they will get a different ip address and break their existing connection to applications.  There are times when a user can be on the first floor and connect to an access point on the second floor.  It makes more sense to have everyone in the same wireless VLAN on both floors.
    In addition, you have to create and manage a configuration that detects what floor a user is on and switch vlans;  that adds complexity and administrative overhead.  You also have to add and manage another VLAN to your routing infrastructure, which will waste ip addresses if the VLANs are not full.
  • 5.  RE: How to assign Vlans for different AP group with internet up-link vlan
    Posted May 17, 2017 10:49 PM
    You need to remember that the APs on the 2nd floor will support some of your clients on the first floor. Unless there is a security issue there is no reason to have floor 1 and floor 2 on a separate VLAN.
