How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
  • 1.  How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 02:41 AM
    We have two controlers Wifi and two differents domain AD (with no approbation), and one Clearpass, the EAP termination is not on the controler.
    With MSCHAPv2, is it possible to authenticate* users via 2 differents AD domains with only one CPPM ?
    * Not only for used for user lookup and attribute fetching.
    Regards
    Yann
  • 2.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 04:00 AM
    Yes. You can join multiple domains and add multiple AD auth sources in the service.
  • 3.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 04:06 AM
    Hi Tarnold,
    I have all ready add my two AD in auth sources.
    I tried to do this, but it's doesn't work, i have this error message when i want to authenticate one AD user on my wifi 802.1x.
    RADIUS
    MSCHAP: AD status:Reading winbind reply failed! (0xc0000001)
    MSCHAP: Authentication failed
    EAP-MSCHAPv2: User authentication failure
    Regards
    Yann
  • 4.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 04:11 AM
    Make sure you joined CPPM to the domain and the read account in the auth sources has sufficient privileges.
  • 5.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
  • 6.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 04:31 AM
    Hi Tarnold,
    Thanks you for your answer, but it's no possible to join two differents domain with only one Clearpass.
    Have you another way ?
    Regards
    Yann
  • 7.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 04:48 AM
    Yes you can.
    Here you can see that Im joined to 3 domains that do not have any trust between them.
  • 8.  RE: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
    Posted Dec 30, 2014 05:07 AM
    it's true, I had not seen !!
    Thanks Tarnold !
