last person joined: 9 hours ago
How to blacklist a client on Aruba OS8?
This thread has been viewed 40 times
  • 1.  How to blacklist a client on Aruba OS8?
    Posted Oct 05, 2017 10:43 AM
    How do I blacklist a client on Aruba OS 8?
  • 2.  RE: How to blacklist a client on Aruba OS8?
    Posted Oct 05, 2017 11:19 AM
    You can use the command " #stm add-blacklist-client <client-mac> to blacklist a client. To verify, use "show ap blacklist-clients".
    Example,
    (Rajaguru-INFINITY-MM) [mynode] #stm add-blacklist-client 22:22:22:22:22:22
    <cr>
    (Rajaguru-INFINITY-MM) [mynode] #show ap blacklist-clients
    Blacklisted Clients
    STA reason block-time(sec) remaining time(sec)
    11:11:11:11:11:11 user-defined 80 3520
    22:22:22:22:22:22 user-defined 5 3595
  • 3.  RE: How to blacklist a client on Aruba OS8?
    Posted Oct 05, 2017 11:21 AM
    Is available in the web ui?
  • 4.  RE: How to blacklist a client on Aruba OS8?
    Posted Dec 03, 2018 10:14 AM
    >in MM node navigate to Configuration > Auth > L2-Auth
    >select the dot1x auth. profile from  the list.
    >Enter a value for number of auth. failures before blacklist at Max auth. failure option.
    > click on submit.
    Find the screen shot attached one.
  • 5.  RE: How to blacklist a client on Aruba OS8?
    Posted Aug 01, 2019 09:34 PM
    Is it still possible to make the blacklist permante?  Ive attempted
    ap ap-blacklist-time 0
    But get an error.
  • 6.  RE: How to blacklist a client on Aruba OS8?
    Posted Aug 02, 2019 01:49 AM
    You can set the blacklist timers in the VAP. The timer named "Blacklist Time" applies to manual blacklisted clients too.
    I don't know of a way to set different timers to individual clients. I don't think that's possible.
    Edit: To answer your question, set the blacklist time in the VAP profile to 0 to make it permanent.
