How to bulk import users into the internal database using Aruba Instants and Airwave
  • 1.  How to bulk import users into the internal database using Aruba Instants and Airwave
    Posted Aug 05, 2015 01:57 PM
    Hello, I want to bulk import users into the internal database of my instants using Airwave. I see where you can input individual entries, but I would like to bulk import them with a CSV file. Is this possible?
  • 2.  RE: How to bulk import users into the internal database using Aruba Instants and Airwave
    Posted Aug 05, 2015 02:03 PM
    Easiest thing to do would be to take an excel sheet and built out the
    commands with a concat function and then paste them into the CLI.
  • 3.  RE: How to bulk import users into the internal database using Aruba Instants and Airwave
    Posted Aug 13, 2015 01:35 PM
    Thanks Cappalli
