How to change ADP interface AOS 8
  • 1.  How to change ADP interface AOS 8
    Posted Nov 29, 2019 10:51 AM
    I have a controller with 2 interfaces
    Interface A: 10.0.0.1/24
    Interface B: 192.168.100.1/24
    Interface A is also controller-ip
    My AP will connect to interface B based on ADP discovery
    DHCP is not comming from the controller also he is not gateway because it is a non-routed.
    Now when we do this we get 10.0.0.1 back as ADP server on interface B
    Can we change the ADP interface so it give back IP of interface B
  • 2.  RE: How to change ADP interface AOS 8
    Posted Nov 29, 2019 12:02 PM
    Your ADP interface is the controller-ip.  If a device discovers the controller on a different interface, the access point will still be redirected to the controller-ip.   You can only change this, by changing the controller (management) ip.
  • 3.  RE: How to change ADP interface AOS 8
    Posted Dec 02, 2019 07:18 AM
    Hello cjoseph,
    Thanks for the reply. I know enough
