How to change am-mode to ap-mode
  • 1.  How to change am-mode to ap-mode
    Posted Nov 22, 2011 01:47 PM
    I don't need Air Monitor in my environment and select ap-mode in Radio Profile but 3 of my AP-61 become air monitor, while AP-105 work in proper ap-mode. how i can change AP-61 air-monitor to AP
    controller is A-200 with OS v. 5.0.3.3.
    Thanks.
  • 2.  RE: How to change am-mode to ap-mode
    Posted Nov 22, 2011 02:06 PM
    Under the ARM profile, do you have "Mode-Aware ARM" disabled?
    Also, you don't have any specific ap-name configurations that are overriding your ap-group config, do you? You can run "show ap config ap-name <ap_name>" to see from which profiles it is getting its RF configuration.
  • 3.  RE: How to change am-mode to ap-mode
    Posted Nov 23, 2011 09:17 AM
    You may also want to check to see if you have any AP Specific configurations set for the AP-61's.  They would be listed by AP Name in the configuration file near the bottom.  When set the parameters there override the global profiles for the AP Group they are a member of.
  • 4.  RE: How to change am-mode to ap-mode
    Posted Nov 24, 2011 07:16 AM
    The will be 2 radio profiles in VAP, one for 802.11a and one for 802.11g so make sure both are set to a profile which has the correct ap-mode set.
    James
