last person joined: 9 hours ago
How to change an Aruba 7005 Controller's IP address
This thread has been viewed 41 times
  • 1.  How to change an Aruba 7005 Controller's IP address
    Posted Oct 24, 2018 10:56 AM
    I am new to setting up Aruba Wireless network and I am setting up different Controllers for the first time.  We have a few 7005 controllers that we would like to test in a lab environment and then move to production.
    But before I plug the 7005 controllers into a production network I will need to change the IP address currnelty associated with interface VLan-99.  I will also need to change the ip default gateway as well.
    Question1:  How can I change the IP inforamtion for interface vlan 99 without resetting the controller back to factory default settings?
    Question2:  How can I change the IP default-gateway to a different IP address without resetting the controller back to factory default settings?
  • 2.  RE: How to change an Aruba 7005 Controller's IP address
    MVP EXPERT
    Posted Oct 24, 2018 11:13 AM
    1) Change the IP address of a VLAN interface
    (Aruba620) (config) #interface vlan 99
    (Aruba620) (config-subif)#ip address [IP ADDRESS] [SUBNET MASK]
    2) Default gateway
    (Aruba620) (config) #ip default-gateway [IP ADDRESS]
    3) If you need to change the management VLAN of the controller to use VLAN 99:
    (Aruba620) (config) #controller-ip vlan 99
     If you need to delete any of the existing IPs (such as default gateway) use the #no statement before
    (Aruba620) (config) #no ip default-gateway 1.1.1.1
  • 3.  RE: How to change an Aruba 7005 Controller's IP address
    Posted Oct 24, 2018 11:48 AM
    Very good!!  It is the same as changing the IP informatin on an HP ProCurve Ethernet Switch.  I wanted to verify that was the case with somenoen that has actually done it before.
    Let me ask will I need to remove the IP address first?  By typeing 'no ip <ipaddress> <sbnet mask><enter>
    Then write memory and tthen type the new IP address in via your instructions
  • 4.  RE: How to change an Aruba 7005 Controller's IP address
    MVP EXPERT
    Posted Oct 24, 2018 12:00 PM
    For the interface you can get away with
    interface vlan 99
    no ip addr
    Sent from my iPhone
